Results 1 to 10 of 12
Thread: New 1993 525i (M50) Belts / Pulleys
    Long Beach, CA
    Default New 1993 525i (M50) Belts / Pulleys
    Just bought a 1993 525i (M50). It has 149,000 miles on it. I'll post pictures later.
    I'm getting a part order together and am replacing the 2 serpentine belts and the pulleys? / idlers? / tensioners? I see there is a mechanical and hydraulic version of the system? How do I tell which I have?
    After verifying which I have, does anyone have a parts list for me?
    Oldham, England
    Quote Originally Posted by uscharalph View Post
    The hydraulic one has a mini shock absorber on it:
    http://www.realoem.com/bmw/showparts...44&hg=11&fg=18
    Long Beach, CA
    Here's a couple of pictures:
    Long Beach, CA
    Apon a very quick inspection this morning (B4 work) it looks like I have the hydraulic version.
    The A/C unit is hydraulic. To see if you have the hydraulic main belt tensioner, look around the alternator area for something with a hydraulic shock.
    Long Beach, CA
    Quote Originally Posted by Rus View Post
    The A/C is the one I saw. Looks like I need to inspect for the other.
    Aug 2008
    Pennsylvania
    When you replace the tensioner on the A/C, or even release the tension from the belt, be extra careful. DO NOT pry on the shock on any mounting points. The best way and safe way I have found is to take a ratchet with a socket, and put it on either the top or bottom bolt(forgot witch, I think it was top) of the shock and turn the bolt clock wise. This will not damage the shock, you will have much better leverage than prying, and takes 30 seconds to slip the belt on.
    Its a good idea to replace the pulleys. The hydraulic tensioner on the alternator uses the same pulley as the A/C belt does. If you have a mechanical, you will need to order a new tensioner. There is also an idler pulley on the alternator, which should be replaced.
    Apr 2007
    TX
    There are two belts, three pulleys, and two tensioners. Replace all of them. The tensioner for the main belt is hidden behind the lower pulley, so you'll need to really look for it. As was mentioned, the hydraulic version looks like a really short stubby shock/damper/strut.
    Long Beach, CA
    So here's what I've ordered so far:
    11281738991 - A/C Serpentine Belt
    11281748131 - A/C Idler Pulley (2 Total - Same part # on Alternator/PS Belt)
    11281437929 - Serpentine Belt for Alternator/PS (May Be Part # 11281469266)
    11281748131 - Alternator/PS Idler Pulley (2 Total - Same part # on A/C)
    11287841228 - Alternator/PS Deflection Pulley
    11281727159 - Pulley Protection Dust Caps (3 - 1 for each Pulley)
    I'm holding off on the Hydraulic shocks / tensioners til we see what's going on there
    Mar 2009
    OZ
    Hi,
    can tensioners be re-adjusted or of a tensioner os nt working right, you just replace it. I am looking to replace both my belts this weekend and was wondering if i should change the tensioners too?
    thanks
  1. Replies: 5
    Last Post: 10-07-2006, 09:07 PM
  2. Replies: 1
    Last Post: 07-12-2006, 03:10 PM
  3. My 1993 525i
    By brillantrot in forum Virtual Car Show 2005
    Last Post: 11-08-2005, 10:25 PM
  4. Noises from pulleys and drive belts
    By Al Gray in forum 5 Series BMW
    Last Post: 10-20-2004, 10:26 PM
