Results 1 to 8 of 8
Thread: 95 525i transmission leak
    Default 95 525i transmission leak
    should I try to fix the leak myself or have it done. It is leaking in the front of the trans where the torque converter is located. Where can I find filters and seals for it. What tools will I need for the job and where to start first. Steps would be cool.
    East Brunswick, New Jersey
    It could be the engine oil leaking from the rear main seal or the ATF leaking from the front seal of the transmission. Either way you will have to remove the transmission to do it. You need a transmission jack to do it.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Aug 2008
    Pennsylvania
    Unless your transmission operates flawlessly, I wouldn't bother.
    I just noticed the leak today and the trany does work well. I think it is the input seal. I just don't know how hard it is to drop the trany in this car
    the repair shop I go to want's $600 should I do it or them?
    Oldham, England
    Quote Originally Posted by bertman609 View Post
    Check the price of the seals. I bet you can buy both tranny and crank seals for USD 20. If you lived next door I'd be more than happy to take USD 600 off you to do it. But do a bit of research and have a think - is it just the seal or is there a bit more to it?
    the seals are cheap. I am just afraid of getting over my head pulling out the tranny. I have changed a turbo 350 in my 72 Pontiac but that is the only transmission work I have done.
    Aug 2008
    Pennsylvania
    It could be your torque converter leaking. Kind of hard to diagnose until you take it all apart.
  1. Transmission Leak from Selector Rod
    By AZ91525ia in forum 5 Series BMW
    Last Post: 02-18-2009, 03:00 PM
  2. Transmission Leak
    By Corvettediesel in forum 3 Series BMW
    Last Post: 09-16-2008, 01:34 PM
  3. Replies: 1
    Last Post: 05-02-2008, 05:32 PM
  4. ZF Transmission leak
    By sevenphotos in forum 5 Series BMW
    Last Post: 02-28-2008, 02:57 PM
  5. Transmission fluid leak
    Last Post: 01-04-2006, 08:13 PM
