Results 1 to 9 of 9
Thread: e34 key fob
    Feb 2009
    wolverhampton,england
    Default e34 key fob
    Does anybody know how to reprogram the e34 520 key fob for the central locking?? Its the type that has the key and fob combined...any help gratefully recieved as this is my 1st beemer
    Jul 2004
    New Haven, CT
    If your car is like my 1995 525i then it is pretty simple. You get the new fob, open it and remove the chip, then remove backseat and put the chip in the alarm box which has a female empty holder for it. you then press a button or so, the actual instructions are here somewhere, and you are done,
    John in CT
    Evanston, IL
    Default Here you go...
    BMW e34 Remote reprog.
    Newer Bmw E34s have a remote to lock unlock the doors and for the alarm.
    If you buy a new remote, you will have to program it. The dealer charges $115.00 to reprogram the remote.
    3 buttons remote p/n: 88-88-1-600-292
    It should also work for the older same looking remote p/n: 82-11-1-467-015.
    Procedure
    • Phillips screwdriver.
    • New remote.
    1. Remove the rear seat bottom section. You will see an alpine alarm box located on the driver side.
    2. Remove the two Phillips head screws that hold the box over and you will see an access door.
    3. Open the door carefully: you will see a small black button and a small slot where the remote chip (eprom) is placed.
    4. Remove the 2 Phillips head screws from your remote fob. You will see a small circuit board, a battery ad a chip. This looks like a very small ram chip on a PC. Carefully remove the chip from the remote and plug it into the empty chip slot on the alpine alarm box.
    5. Put your key in the ignition and turn it to the 1st accessory position (Do not start the car). Go back to the alpine alarm box and hold the black button down for 10 seconds. Remove your key from the ignition.
    6. Remove the chip from the alpine alarm box and put it back into the remote fob.
    7. Re-mount the alarm box and seat bottom. This is it.
    Alternate Procedure from Steward E.
    1. Open the remote by removing the two screws and flip the cover open. If the battery comes out of it's position, make sure you put it back with + facing the correct side.
    2. Remove the chip that is to be programmed. It has a white label with a serial number on it. The chip might come out easily, or you might have to use a small screwdriver to open the socket. The small plastic socket has a front end that can slide out if you pry gently with a small screw driver. This will make it easier to remove the chip.
    3. Remove the back seat of the car (because the alarm unit is under it). The seat cushion is removed by locating the securing clamps, one on each side, roughly in the middle behind the front seat and at the lower end on the front of the back seat. Once you've located the clamp (you can feel where it is, but you can't see it), grab the lower end of the back seat at that point and pull hard up.
    4. The alarm will be under the beck seat behind the driver's seat. Use a 7mm wrench to loosen the two screws on the bracket in front of the alarm. When the alarm is loose, turn it upside down. Open the small plastic panel. Now you will see a socket identical to the one in the remote. Insert the chip in this socket. Be careful and make sure it is inserted correctly. Turn on the ignition on the car. Go back and press the small button to the upper left corner of the chip you just installed. Hold the button down for just a few seconds.
    5. Turn off the car's ignition, remove the chip and install it into the remote. The remote should now work.
    6. Install the alarm unit and back seat and you're all set.
    Marietta, GA
    If you have a key like the one in the picture, which matches your description of the key follow the below directions.
    To program the fob perform the following:
    1. Put key in ignition and turn to position 1 for no more than 5 seconds.
    2. Remove key
    3. Press and hold the unlock button and press the lock button 3 times. The led on the fob should blink a number of times and the doors should all lock.
    4. If you have more than one fob to program start at step 3.
    Feb 2009
    Thanx for those suggestions folks i`ll try them out today...many thanx
    Lexington, Kentucky
    I reprogramed two extra remotes for my 95 525i (I now have 4) using these instructions. Worked fine except I had to do each remote twice??? No understaning why.
    Sep 2005
    NJ
    Quote Originally Posted by Russell View Post
    wanna send me one for like 30 bucks?
    Lexington, Kentucky
    Sorry, not at this time. I want to have a third set of keys/remote and an extra remote-just in case.
