Results 1 to 7 of 7
Thread: valve clatter in the m30
    Jan 2007
    Dayton Ohio
    Default valve clatter in the m30
    Over the weekend I adjusted the valves in my sons 735i. It has an m30. Discovered that one of the banjo bolts was loose and laying on the top of the head. Looked carefully at the cams and checked all of the valve clearances. Only found two valves that were a little tight and readjusted those. Reinstalled the banjo bolts with new aluminum washers and a bolt locking retainer. Have run the car several days now and there is still too much clatter. I have an m30 in my 89 535i and there is less clatter from this engine. What do I do now?
    Jan 2009
    Ann Arbor, MI
    I've adjusted the valves on an M30 just three times now, but I did them right to spec and they're always noisier than when I started. I suspect that when they've been adjusted by a pro mechanic, they get set a little tighter to keep the noise and customer complaints down. If you think it's possible one of the banjo bolts let go, though, you might as well take it back apart....
    Previous owner of my car also mentioned that factory specs are different on the 735 than on the 535 simply because they figured 7-series owners wouldn't tolerate the noise. Dunno if that's true.
    Sep 2008
    Gold Coast, Australia
    Valve clatter is normal. Its when it goes quiet is when you should be worried.
    Canada, ON
    Changing all the excentric can help, sometime they crack or get a flat spot.
    Sometimes the top of the valve is cracked and this also create noise...
    The M30 engine will never be a smooth quiet one. The Injector noise is pretty high also.
    Minnesota
    Default There's a detailed write up over on mye28.com. Check the tech stickies - What can
    Quote Originally Posted by Kibokojoe View Post
    happen is that the top of the valve stem actually get cupped due to wear. Then whe you stick your feeler gauge in, it creates a bridge across the cup and gives a false reading (larger gap). I always set mine based on the gap between the cam lobe and the rocker. I set at GO 0.010 and NOGO at 0.090. This may seem tighter than spec, but the distance from CenterLine of shaft to the valve tip is LONGER than the distance from the Centerline of shaft to the contact point between the cam lobe and the rocker contact point. Therefore, small gap on rocker side creates larger gap at valve tip side. I have done it this way for my 528e and both my 535i's.
    Good luck.
    Jeff in MN
    87 535is 245k Recent top end re-work
    88 528e 290k
    90 535i 115k
    98 740i 115k New Magnaflow Cats, No More Codes
    Canada, ON
    Quote Originally Posted by Jeff in MN View Post
    Good luck.
    Wow, this is an amazing trick.... THANKS
    Minnesota
    Default You're welcome, plus it is a lot easier to get your
    Quote Originally Posted by Bruno View Post
    gauges on top of the lobe and gently adjust the eccentric on the other end. HOWEVER please note I had brain fart in describing the gap. I meant 0.090 Goes in easy, 0.010 Goes in snug, and 0.011 is a NOGO. Sorry for the confusion.
    Jeff in MN
    88 528e 290k
    90 535i 115k
  1. Replies: 2
    Last Post: 03-25-2009, 07:47 PM
  2. IAC valve
    By Ross in forum 5 Series BMW
    Last Post: 08-02-2007, 07:05 PM
  3. Disconcerting valve clatter or ping!!
    By helm in forum 5 Series BMW
    Last Post: 08-26-2005, 03:23 PM
  4. EGR Valve
    By jj7 in forum 5 Series BMW
    Last Post: 11-26-2004, 10:15 AM
  5. Valve Clatter
    By DonC in forum 5 Series BMW
    Last Post: 05-29-2004, 05:33 PM
