here is the translation into english; ********
Don't put this crap in your engine
Does anyone speak Polish?
I stumbled on ceramizer product and it looks amazing. you can run your engine without oil. It is supposed to give you back 100% compressions.
http://www.youtube.com/watch?v=3NX5C_J74PU
http://www.ceramizer.com/
I want to try this one out on my M40... it looks magical
1. Protection of dynamic car parts against wear;
2. Recondition of the friction pairs without the need to dismantle;
3. Restored surfaces guaranteed for 70000/100000 km (40000/60000 miles);
4. Reduced fuel consumption from 3 to 15 %;
5. Increase the power and mechanical efficiency of the engine;
6. Protection against corrosion and aggressive chemicals especially when lower quality fuel and lubricants are used;
7. Increased efficiency of the lubrication system;
8. Decreased oil consumption;
9. Longer operating time between oil changes (min 50% increase);
10. Decreased exhaust emission of toxic gases;
11. Decrease in noise level from the engine, gearbox and differential;
12. Lowered vibration level;
13. Reduced friction value to less then 0,02 – ten times less then steel–steel;
14. Extended operating life of all working parts;
15. Increased reliability;
16. Extended operating life of the friction pairs five–times;
17. Lowered working temperature of the engine;
18. In the event of oil leakage and loss quaranteed continual and safe use of vehicle (engine for up to 500 km/ 300 miles, gearbox, reducer, axle up to 1000 km/ 600 miles);
19. Improved engine start especially at low tempratures;
20. Protection against piston ring seizure;
21. Protection of natural environment.
There has been a similar product advertised in the U.S. a while back. The claims turned out to be unfounded. A test had been conducted by a government agency (if memory serves me right) on two identical cars, one without any oil whatsoever, and another with the "miracle" product only, no oil neither. Both cars did the approximate same mileage before dying - a few hundred mile as I recall, somewhere around 500 I think. Which proves any engine can run without any oil at all for some miles before being toast.
The company was forced to withdraw its publicity on television, and cease its false claims.
Magical tricks are just that : tricks. And in this case, a marketing ploy exploiting a fact : engines can run without oil for miles.
Slick 50 is a product that claims similar engine protection. A long time ago I put this stuff in my wife's dodge minivan (mitsibishi 3.0 ltre) and she ran the car with less then a quart of oil for awhile. She told me to look at it because it kept stalling on her. Turns out it was over three quarts low. Car went another 40k.
So in my opinion there is something to the teflon stuff or PTFE as they call it.
Don't think I would put it in any of my bimmers though. Even if the idiot light works you should check the oil once in a while.
or simply use synthetic oil and keep it closer to full than empty.
Name of product? There were several similar ceramic products discussed on bobistheoilguy forum. Some were used/tested by members. If I remmember correctly, none really seemed to work reliably. However there were individuals that claimed sucess.
If it was that good, BMW would be advertising its use in new cars.
And the aerospace industry would be buying it by the trainload.
Until they do, smile and move on......
my cousin tells me it wouldn't help the industry as people wouldn't buy new cars.
he knows people in the truck industry. they make it so that after you repay the credit (5 years) of your truck. your truck engine fail (after 400 miles) due to wear and you buy a new truck,
I don't see how Aerospace would use it.
besides most people in the West don't want old cars. They want new bling bling stuff. the rationale is only for poor eastern countries like Poland with lots of old cars.
