Results 1 to 8 of 8
Thread: Engine coming out, What to do??
    Jan 2005
    Melbourne Australia
    Default Engine coming out, What to do??
    Pulling the engine out of my 94 540 Auto to re-seal, rebuild power steering pump seals and power steering hoses to try and eliminate all those pesky leaks.
    Pull and clean the fuel injectors will be included
    Engine has had compression checked and is good. 333,000 km on clock
    What else should i be doing with out spending too much?
    am not currently disassembling the engine so the piston rings/seals etc are not being done.
    Have been quoted $1200, 1500 is my budget.
    Thoughts and ideas appreciated.
    Timing chain; main bearings;
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    drop the pan, count and reinstall the oil pump bolts that have fallen out.
    HAhahaha! So common I forgot to mention this.
    Quote Originally Posted by Ross View Post
    Jan 2005
    Melbourne Australia
    Should have that picked up on the pan re-seal.
    come on guys,, got some money to spend, need direction
    1994 540i Auto
    East Brunswick, New Jersey
    The sump pan cover is so easy you do not need to pull the motor to do it.
    sump pan gasket (BMW changed it to a metal gasket)
    oil lever sender o-ring,
    front seal,
    rear main seal,
    valley pan (BMW no longer sells the gasket you need to buy a new pan),
    battery cable fixings above the valley pan (you'll find them all disintegrate to the touch)
    battary cable sheath (get it from Autozone)
    water pump anf gasket,
    thermostat housing and gasket,
    intake manifold gaskets, four pairs of little ones and two big ones,
    misc orings (four coolant pipe o-rings, two crankcase vent pipe o-rings)
    oil passage o-rings in the driver side engine mount,
    o-rings on the braided hoses to and from the oil filter
    rear coolant header gaskets.
    exhaust header gaskets, header nuts,
    valve cover gasket and cover bolt rubber cushions.
    These are on the top of my head.
    It's going to cost you unless you do it yourself.
    I doubt if you need to touch the timing chain, guide and bearings. If you do it is easier and cheaper to get a younger V8 from the junkyard.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Quote Originally Posted by stx133 View Post
    I'll PM my paypal
    Jan 2005
    Melbourne Australia
    I'll PM my paypal
    I am doing around 1000km a week, investing in reliable comfortable enjoyable transport is a valued priority, 'buying' people i can do on face book (if i had an account)
    1994 540i Auto
    Jan 2005
    Melbourne Australia
    Quote Originally Posted by yaofeng View Post
    You luck people in the states have much better (cheaper) access to seccond hand parts. a junkyard M60 would cost over $5k here in the wonderful land of Oz
    1994 540i Auto
  1. It's coming...
    Last Post: 06-04-2006, 09:11 AM
  2. Anyone coming to O'Fest?
    By billb in forum 5 Series BMW
    Last Post: 10-03-2005, 01:53 PM
  3. im coming from a new mac
    By kyleN20 in forum 5 Series BMW
    Last Post: 09-08-2005, 07:05 PM
  4. Oil coming out of the MAF
    By Denasti in forum 5 Series BMW
    Last Post: 04-01-2005, 08:20 PM
  5. What could that be coming out of #6?
    By Adnan in forum 5 Series BMW
    Last Post: 12-04-2004, 09:47 PM
