Results 1 to 10 of 15
Thread: DTC option
    Apr 2005
    Canada
    Default DTC option
    Does BMW equiped with DTC option (Dynamic Traction Control) all (E34, E39, E60) have LSD differential, or this function assured by other means ?
    no it does not, if it did then traction control couldn't independently control the rear wheels.
    Quote Originally Posted by Claude View Post
    Apr 2005
    Canada
    Is it to say that if you disactivate the DTC function in the snow (or wet pavement) you may have a free spinning rear wheel meaning no traction at all ?
    Yes. As regal said, those cars don't have an LSD. The only other differential available is the open diff, which would allow one wheel to loose traction without the DTC enabled. At least that's the logical conclusion.
    Apr 2005
    Canada
    Quote Originally Posted by Rus View Post
    If it's really the case it's a real MINUS for us in northern region in winter time when stuck in the snow: With DTC ON you're not able to move because if a wheel start spinning... and it will... power is cut off so you'll not move for sure and with DTC OFF and an open differential if a wheel spin free... and it will... even if the other wheel could found / give some traction this one will not help because only the one that spin free (on ice for exemple) will rotate. Comclusion: One (in ours northern countries) will be better off with a car e/w LSD than with DTC That's my understanding, I am right ?
    Sep 2007
    Seattle, WA
    I don't know about DSC, but on cars with ASC/ASC+T you can install an LSD into them and use both or just the LSD. ASC/ASC+T is pretty simple. It just sense when a wheel is slipping and in the case of the rear wheels applies the brake to the slipping wheel and it cuts the power back with a secondary throttle body. And LSD would prevent the ASC/ASC+T from kicking in most of the time as it'd prevent wheel spin a good bit.
    DSC does more than that, but you should be able to install LSD's in DSC equipped cars. The E39 M5 has DSC & an LSD. Don't see why you can't add an LSD to an E39 equippe with DSC.
    Apr 2005
    Canada
    Quote Originally Posted by bubba966 View Post
    I've ask the dealer he said : M3 and M5 models are e/w LSD diff but all other's with regular (open) diff.
    Sep 2007
    Seattle, WA
    On the '95 540i M-Sports both LSD and ASC+T were options. I do believe that a few cars have both. Mine has ASC+T, and I've got an LSD sitting around to put into it at some point. No big hurry as I don't really need LSD. Need good winter tires more than that as the ASC+T set to snow mode actually works pretty decently.
    Twin Cities, Minnesota
    Try driving up an icy drive with ASC + T. Never make it up. The rev limiting feature kicks in and kills any momentum. It needs to be disabled (Search forum for how) and then you can do it.
    Disable the stupid system and use your parking brake as limited slip if your rear is slidding around.
    And put in the LSD like BMW should have done in the first place.
    Cheers,
    Fin
    Isn't there a way to disable the power limiting feature of the ASC? Hold the button until the light flashes or something like that, I did it once but....Or does it disable the anti-lock and keep the trac control on?
  1. Is this a RARE E39 option?
    By AngryPopTart in forum 5 Series BMW
    Last Post: 01-13-2008, 09:54 AM
  2. Underseat tray option on E34
    By ktteoh in forum 5 Series BMW
    Last Post: 01-19-2007, 04:56 PM
  3. M20 with 5sp auto was this an option?
    Last Post: 03-14-2006, 03:29 PM
  4. I need e34 v8 owner's option!!!!
    By chefdanny121 in forum 5 Series BMW
    Last Post: 11-24-2005, 11:29 PM
  5. Best option to get cd capability.
    By olsan100 in forum 5 Series BMW
    Last Post: 08-25-2005, 04:30 PM
