Results 1 to 4 of 4
Thread: Temperature off by 7c/12F
    Jan 2008
    Sweden
    Default Temperature off by 7c/12F
    Wtf.. Isnīt that a bit ridiculous?
    My external temp gauge is off by 7c/12F, how can that happen overnite?
    My first thought was that the foglights radiated some heat to the gauge as I use them exclusively in daytime but no.. Even with the foggies turned off the temp is 7c/12F higher than the actual outside temp.. Maybe a reset by disconnecting the battery will help, but if any of you guys have some idea as to why Iīd like the info so I can fix it!
    Could it be that my temp gauge is psychic and is able to show the consequences of climate change?
    There is probably corrosion in the connector to the sensor
    +1 on the dirty connection. The sensor is a thermocouple, which depends on good connections for its signal to be interpreted correctly. Some contact cleaner might just fix the issue.
    Jan 2008
    Sweden
    I think you guys are right, today its off by 2.5C only so.. Thx!
  1. (2) Temperature Sensors?
    By tomd365 in forum 5 Series BMW
    Last Post: 05-20-2007, 09:28 PM
  2. Engine oil temperature
    Last Post: 04-11-2006, 04:08 AM
  3. Coolant Temperature
    By bimmer525 in forum 5 Series BMW
    Last Post: 03-16-2006, 07:16 AM
  4. Temperature and gas mileage?
    Last Post: 08-04-2005, 08:27 AM
  5. Outside temperature reading on OBC
    By glen-sj in forum 5 Series BMW
    Last Post: 02-18-2005, 10:00 PM
