Results 1 to 10 of 12
Thread: Fan Blower problems
    Nov 2006
    Maryland
    Default Fan Blower problems
    I'm having intermittent issues with my fan blower speeds. Most cold mornings my fan does not work at all. I jsut get a slight breeze coming out of the vents on all settings. while driving, it sometime sjust kicks on, then sometimes kicks out and stops working. I have an 02/89 production 535i. also, sometimes when it's on the fan makes a wierd hum noise, could be becuse of the cold weather? So anyways, rebuild or get new sword? or is it something else?
    Thanks.
    Apr 2008
    Washington DC
    Quote Originally Posted by ///Sniper535 View Post
    Thanks.
    That sounds very much like a sword problem. Extreme cold can crack soldered areas and show brittleness. Rebuilt one is cheaper and if done correctly will last longer than a used one. If the sword is damaged, the wrong and intermittent voltages being fed to the fan motor can cause weird noises.
    1989 11/88, M30B35 175k-miles 535iM
    1988 04/87, M20B27 153k-miles 528e
    1987 01/87, M30B34 126k-miles L6
    Washington D.C
    Jan 2007
    Dayton Ohio
    Fix the sword, I rebuilt mine for under $10 USD. Not to tough to do either. BUZ71A MOSFETS are cheap
    http://www.bmwe34.net/Wiki/tiki-inde...ower+and+Sword
    Do a google search on sword bmw repair
    Jan 2007
    Dayton Ohio
    Here is a how to that is really good
    http://www.bimmerboard.com/forums/posts/355700/
    Nov 2006
    Maryland
    So does an 02/89 have a sword and resistor pack or is it just one or the other?
    Jan 2007
    Dayton Ohio
    My 89 535i has the sword, I am sure yours does too
    there is either one or the other, because both have the same function.
    Jan 2007
    Dayton Ohio
    So BMW didn't pick specific models and years for sword or resistor?
    looks to me they switched on newer models to the resistor, because that is maybe smaller and easier to install, and/or cheaper production cost. Older E34 have swords, then it changed to resistor, all E32 have swords, either from Siemens (mostly in Europe and on E32 w/o AC) or Behr. The Siemens cannot replace a Behr, different shape and different system. The Siemens sword is shorter, but wider compared to the Behr. Very difficult to get a used Siemens, even in Germany.
    May 2006
    Antwerp, Belgium
    Don't forget the possibility that it's just the fan speed dial itself.
    see:
    http://www.bimmernut.com/forum/showthread.php?t=35780
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
  1. More Blower Problems
    By semiretired in forum 5 Series BMW
    Last Post: 12-08-2006, 08:32 PM
  2. Blower Fuse Problems
    By 01'330i in forum 3 Series BMW
    Last Post: 08-07-2006, 10:41 PM
  3. fun blower
    By kofibimer in forum 5 Series BMW
    Last Post: 06-26-2006, 10:46 AM
  4. Blower
    Last Post: 11-18-2005, 12:50 AM
