Results 1 to 3 of 3
Thread: Door Brake Has Torn Door Sheet Metal
    Default Door Brake Has Torn Door Sheet Metal
    So like an idiot I never put a reinforcement plate on my 235k mile baby and although it has not broken all the way throug, the break has torn the sheet metal on the door. Would installing the KMS plate with JB Weld do the trick or do I need to get the sheet metal welded properly for the plate to work?
    Thanks in advance,
    Kevin
    95 540i Sport (EDC replaced with Koni/Eibach) 235k
    Apr 2007
    TX
    Not to hijack, but can someone tell me if this is a weakness that affects all E34 model years? Is this fix something to do as a PM? When do they usuall fail?
    As far as what I have seen from the fix, you use JB Weld and large washers. Don't think there is a need to weld.
    May 2006
    NH
    You can just put the plate on as is. Mine ripped thru the sheet metal too. You just screw the two fasteners thru the plate back into the brake... the plate is thick and long enough it should still have plenty of area to cover.
    1995 540i Manual build 1/95
  1. Door Brake Issues
    By ILoveMPower in forum 5 Series BMW
    Last Post: 11-07-2008, 01:54 PM
  2. E34 door brake lubrication
    By ktteoh in forum 5 Series BMW
    Last Post: 10-06-2006, 05:00 PM
  3. rust-proofed sheet metal
    Last Post: 10-31-2005, 04:52 PM
  4. 1995 540 L/H Door Brake Seperation from Door
    By Wilbranka in forum 5 Series BMW
    Last Post: 05-31-2004, 05:48 PM
  5. Help! Drivers side door metal is ripping
    By Russ in Seattle in forum 5 Series BMW
    Last Post: 02-15-2004, 09:26 PM
