Where do you see the torque value? I am almost sure you are mistaken. There is no big bolt on the flywheel. The rear seal has m6 and m8 bolts. The front crank does require high torque but using an air impact won't give you that.
Hello,
I want to do my rear oil seal... however I saw in the manual that I will meet with bolts torqued to 400nm (the flywheel).
there is no way to remove them by hand right?
so i'm bound to buy an impact wrench and a compressor.
Is a 25L compressor enough for the job or do I have to buy a 50L compressor? (I hope not because they are big and I don't have much room)
I also want to be able to remove the front crankshaft bolt. I have seen a friend enable to remove that bolt with a basic compressor.
How much power do I need?
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
torqued to 105nm and the crank bolt on the front is torqued to 320nm
you can lock the flywheel from turning with any number of things, put a socket of the front pulley to hold the crank from turning. And use a long breaker bar to break the bolts loose,76 ft. lbs isn't that bad. Now the front crank bolt is alot more fun without the right tools.
any use for the crank bolt?
http://www.zdmak.com/wbstore/main.as...3034SET&CTMP=1
The front crank bolt is a completely different animal from the rear flywheel bolts. If you need to do that one, you'll likely need the following:
- the hub lock tool you listed above.
- a very solid breaker bar
- a jack handle or something that will extend the breaker bar handle for leverage
This will get it off.
To install correctly, you would need a torque wrench that will read up ~ 325 lbs. When we've done it, we've never had one handy so we've always estimated the torque. We do this by seeing how long the lever arm is on the breaker bar and the assessing the required pull based on that arm. For example, if you have a 3 foot arm, you need just about 100lbs of pull. If you have some experience, it's not too hard to estimate this how hard this is. A torque multiplier is also another tool that can solve this problem but we've never had one.
Done several front crank nuts this way, never had any problems.
Bellevue WA
86 Porsche 951 - Track Toy
IIRC, the front needs a 27 mm socket. A 1/2" drive breaker bar with extension and a bathroom scale will give you the approximate torque you want. As to the flywheel insert a 1/4" punch through a hole below the starter at No.1 piston TDC to lock it. Remove the plastic plug from the hole first.
'01 540it, 6/01
'10 535ix. 9/09
'10 mini 6 speed
