Results 1 to 5 of 5
Thread: 55 MPH Wobble - some collected solutions that worked for me
    Mar 2004
    Default 55 MPH Wobble - some collected solutions that worked for me
    Anybody with an E34 55mph wheel shimmy? These are things I did on my '95 and now am very happy
    1) If you have original tires/wheels – are they balanced and “round”? Have you swapped them front to back to verify it is not the tires/wheels?
    2) If you have aftermarket wheels – do they have needed adapters so that they are hub centric?
    3) If you have shimmy only while braking – check your rotors for out of roundness
    An alignment won’t hurt to verify that things are in good working order (although only front toe in is adjustable) front and back.
    Okay, now for the fixes (and I don’t take credit for these, just that I have been through this and now drive a 95 that feels awesome):
    1) Appropriately jack up the car on one side (I suggest passenger) and grab the raised front wheel laterally (3:00 and 9:00) and try to rock it in and out alternatively (pull with one hand, push with other). Best if someone holds the steering wheel to prevent motion there. If there is slop in the wheel movement, you know you have an issue. In my case I could hear something up front and then see about 1/8” of free lateral (like a tie rod was shot) motion on the passenger wheel. I should point out that I had new control arms, M5 bushings, tie rod ends and new center/drag link and I knew my idler was fine when I saw this motion. Look for joint boots that are cracked – this is a sure sign that you will have ball joint problems in the future. Any noted slop here could be wheel bearings (I have not replaced any of these on this car) or joints/bushings in the front end. This is the hard part – you may need to temporarily remove some joints to see where the slop or bad joint is located. If nothing looks obvious, you may want to shoot to step 2 as it may get your front end 55mph wobble “good enough”. Don't forget to check your bushings - they may be completely shot although I could not detect this without removing them. I suggest Lemforder, they seem to work unless you really like to experiment and/or swap out front end parts.
    2) Tighten the collar nut on the steering column! I did this last and really regret not doing it sooner as it is so simple and was a fairly large contributor to the problem. It should be the first thing after careful inspection of the front end for obvious problems as noted in step 1. Use this time to visually inspect that your flexible coupler (close to column) is in good condition and bolts are present. Tightening the collar nut too much will jam the column extension motor. I tightened mine by removing the panels so that I could get full access to the collar which is a bit of a pain but worth the time it takes. It would be a great time to replace that brake switch that you know is going to fail. It takes about 30 min if you take your time to take the panels off and do the adjustment. By the way, the symptom of a loose nut is that there is a non-directional clunking sound (and mine was obvious) when moving the steering wheel back and forth lightly in the “slop” or deadband (friction force only) zone. Refer to http://www.bmwe34.net/Wiki/tiki-inde...=Steering+play
    3) Steering box adjustment – I say this with much trepidation as although it can solve some backlash problems, you do take risk that you may cause castering to be degraded and possibly even cause damage to the box. There is an adjustment on the top (17mm lock nut if I recall correctly) with an Allen center adjustment. I only moved mine about 90 deg (CW) and it made a noticeable difference. Again warning, tightening too much could make the car not caster properly (wheel centering) or cause excessive friction or failure of the bearings. Again the above link has some description of this as well. There are more links here but this was the quickest I could find.
    Enjoy,
    Scott
    07 525i 22K, 07 328xi (41K)
    Jan 2005
    Melbourne Australia
    Have myself spent conciderable time on trying to delete the dreaded 'shimmy', what was found at the end of the search;
    hexagonal tyres, when the tread had worn down to the indicators on the rear, multiple flat spots. how messed up..
    this was transferring through when braking to give the shimmy.
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    May 2008
    Louisville, KY mostly
    Thanks for the info. Does anyone have more detail on out-of-round original wheels? I've heard of this from time to time with other posts / sites. Mine is a '93 with originals & throwing star inserts (I know the inserts don't matter, but thought I'd throw it out there in case someone knows of dates / vin numbers where original wheels were thought to be imperfect).
    The reason I feel my shimmy may be in the wheel roundness is that I've tried two types of tires, rotations, and also have well inspected, and replacement of tie rods, steering column nut as mentioned, and bushings (no play in front end from multiple inspections from my veteran E34 specialist). The shimmy is also very even throughout the car, (seats and all right at 55mph). Smooth as silk at ALL other speeds.
    I don't want any aftermarket wheels, and not sure what route to take to either correct current wheels or order new originals. Any help appreciated.
    AJ
    93 M5
    • SLS removed
    • Supersprint
    • Autothority
    Mar 2004
    Quote Originally Posted by 93AlpineII View Post
    Does it change "at all" if you rotate wheels/tires front to back? Idler arm (mine was fine) and center/drag link okay?
    Recheck the Collar nut - is it tightened enough? It really does make a big difference. Have you done the steering box adjustment?
    Best wishes,
    Scott
    May 2008
    Don't think it changed at all for front to back rotation. And, my mechanic already tried the collar nut thing. However, your mention of the steering box interests me, as my car's other issue is too much play at center. Car will creep on its own when driving straight and my bushings and other suspension checks out tight. Look forward to any tips you have or have heard...
    AJ
    AJ
    93 M5
    • SLS removed
    • Supersprint
    • Autothority
  1. Cool, Calm and collected :) !
    By philbyil in forum 5 Series BMW
    Last Post: 10-08-2010, 09:09 AM
  2. car won't start in winter? symptoms/solutions
    Last Post: 01-01-2010, 06:08 PM
  3. Collected a big box today!
    By Uber Soldat in forum 5 Series BMW
    Last Post: 02-25-2007, 02:18 PM
  4. collected the 91 e34 525i i bought a few weeks ago
    By cooljules in forum 5 Series BMW
    Last Post: 02-18-2007, 10:07 AM
  5. Any new solutions to an old problem?
    By Eric540i in forum 5 Series BMW
    Last Post: 11-19-2006, 11:08 AM
