Results 1 to 10 of 16
Thread: air cond funny buggers
    Jan 2005
    Melbourne Australia
    Default air cond funny buggers
    I have the 94 540, has the final revision of the climate control with independant control on drivers / passengers and uses dial type slides for temp and fan control (as used in the next 5 series )
    fan is behaving peculiarly at the moment, will some times turn itself up or down when the slide is left at about 1/3
    now some times it will not come on above low, even when switched to max for up to 10 min of driving.
    has always been fairly ineffective, i can fart harder than the air that comes out the side vents on the doors. i dont think i have a 'pollen' filter and it makes no difference if i am on fresh air or recirc air.
    Q? is recirc air drawn through a filter? is there a pre filter that can be cleaned - removed? how do i check for normal / optimal operation
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    I'm confused with your desciption of your controls. the next(E39)series used controls not even remotely similar to the E34.
    Your '94 does have the filter, sounds like yours is probably full of dirt. The fan speed issue could be the resistor for the blower or a faulty control.
    Feb 2007
    GreenHills East-Philippines
    Your blower issue could be the sword, blower motor , or switch. About the air your a/c filter might be clogged. if your e34 does not have cabin filter you just have to clean your system. bout d fart, dang thats a loud fart
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Feb 2005
    Grand Marias USA
    I don't think he has a sword
    Jim
    Feb 2007
    Quote Originally Posted by guinness View Post
    Jim
    resistor pack?
    fan sounds erratic for sure, have you changed the microfilter? that will account for the air flow. Mine was completely black when I pulled it.
    Nov 2006
    Mid-Atlantic, USA
    If you're referring to the automatic-type controls like this, we had them in the USA on some E34 M5s. They're like an E32 7-series, not much like an E39 Five. I don't like them, but no matter. They take the same fan resistor and the same micro-filter. You likely need both.
    Yes, he has resistor pack like I do. Same thing over here... fan was weak no matter what... changed out the resistor pack and everything is back to normal.
    Reading, UK
    Resistor pack in a climate contol model? I thought it was transistor pack controlled, aka the sword? (My climate controlled 94 TDS had a sword in it?)
  1. E34: WOT throttle kickdown switch/air-cond mod
    By ktteoh in forum 5 Series BMW
    Last Post: 07-31-2007, 08:01 AM
  2. M50 Engine rpm control with air-cond compressor ON
    Last Post: 01-23-2006, 09:50 AM
  3. Those pesky brake sensors are buggers!!
    By Am Piobaire in forum 5 Series BMW
    Last Post: 04-28-2004, 07:35 AM
  4. broken air cond.
    Last Post: 04-06-2004, 01:22 AM
