Results 1 to 7 of 7
Thread: Is my car in limp mode?
    Jun 2006
    southaven miss.
    Default Is my car in limp mode?
    I have a 94 530it that i got cheap and have been fixing up. Just replaced the brake booster and got my brakes working great. Took it for a drive and car accelerates very slow and will not go above 40mph. I can see the rpm's shifting, but car takes forever to move. The first time it cleared up and car drove great, parked it at home then next day it started driving slow again and now it's staying that way. Does this sound like limp mode? I have disconnected the battery for a day,no help. I dont have a transprogram message. Thanks
    what codes do you get after the stomp test?
    Jun 2006
    southaven miss.
    Im not getting any codes from the stomp test
    Derbyshire, UK
    Plugged cat, exhaust, or intake, maybe?
    1997 535i V8
    Does your car have EML at all? That means fly-by-wire, so electronic accell and on the throttle valve there is a motor instead of a bowden cable.
    On a car with EML it could be limp mode, because the EML will go into limp mode if for example a wheel speed indicator does not give a plasuble signal.
    Windy City
    It can be your MAF (Mass Air Flow) sensor. It is located between air filter box and intake. Try cleaning it first. You can find MAF sensor cleaner in any auto parts store. But most likely it is bad from your description. Important Note: DON'T TOUCH THE SENSOR LEAD as it can be damaged easily. But you should check for fault code first so you don't waste money and time fixing something that's not broken...
    Quote Originally Posted by barry 90 525i View Post
    RICK
    BMW 1995 525i (Alpine White)
    Twin Cities, Minnesota
    Barry,
    Welcome to the Touring club!
    My 94 530iT never responds to the stomp test, so I'm not surprised that yours doesn't either.
    Limp home acts like a car needing a tune-up or a sparkplug not firing rather than like something seriously wrong. Not the case here as it ran great once.
    Best of luck troubleshooting,
    Fin
  1. Sport Mode !
    By Roderick in forum 5 Series BMW
    Last Post: 07-01-2007, 01:33 PM
  2. My E34 is stalling. (limp??)
    By thatracer in forum 5 Series BMW
    Last Post: 01-22-2007, 11:11 AM
  3. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  4. Replies: 8
    Last Post: 09-18-2005, 01:40 PM
  5. 535i AT in Manual Mode vs. Economy Mode
    By xtmsports in forum 5 Series BMW
    Last Post: 03-22-2005, 07:23 PM
