Maybe also a worn throttle cable? I had my throttle cable replaced and it was by far the best £70 I've ever spent on a car - no more sticky, jerky response.
Car had been getting stuck in high idle after initial drive on very cold mornings recently. It would get stuck anywhere between 1 and 3k rpm. It was the Gas pedal . it was getting stuck,lol.. its new so maybe the flex joint stiff from the cold and the pedal wasn't returning to position.. I just reached behind it ,pulled it foreward and bam... idle back to 500 rpm... lol.. sweet.
1995 540i Manual build 1/95
First check your floor mat... make sure it is in the tab and not pushing on the throttle pedal.
Second, clean the ICV valve...
Third, check for huge vacuum leak...
