Results 1 to 4 of 4
Thread: Steering wheel centering
    Aug 2008
    Pennsylvania
    Default Steering wheel centering
    I recently adjusted my gearbox on the steering to take up some of the slack. I turned the adjustment screw about 1/8th of a turn in. I don't exactly remember how the steering was prior to this because I had to correct the car a lot do to the slack in the steering. After the adjustment I noticed that the steering wheel will return to center but not quite center. It will go back most of the way but it will slow down when it has 1/4th of a turn left till complete center and thats where I have to correct it. Is this normal?
    Also, my steering is heavier when its cold than when the car is completely warmed up. The ambient temperatures range from 24F-40F. It is noticeable when its very cold.
    El Paso TX
    if it isn;t self centering, you tightened it up to much. had probably been done before and is at limit of adjustment, which means live with it or replace it.
    try taking the 1/8 turn back out or 1/16 back out.
    Aug 2008
    Pennsylvania
    It didn't appear as anyone tampered with the adjustment bolt and lock nut. The slack wasn't a lot so maybe my adjustments were a bit to much for the slack I had. Thanks for the input.
    Aug 2008
    Pennsylvania
    Well I backed off the screw a bit and its much better. It goes back to center and the steering wheel isn't like brick anymore.
  1. Replies: 5
    Last Post: 12-18-2006, 10:18 PM
  2. Canadian source for hub centering rings?
    By Jay 535i in forum 5 Series BMW
    Last Post: 03-13-2006, 07:12 PM
  3. Clickin noise from wheel/lumping in steering wheel
    By m5james in forum 7 Series BMW
    Last Post: 11-19-2005, 11:26 PM
  4. Centering Rings on Ebay
    By talltorontoguy in forum 5 Series BMW
    Last Post: 11-28-2004, 03:59 AM
  5. Wheel aligment/steering wheel question.
    Last Post: 08-25-2004, 06:04 AM
