Time already to replace the one which replaced this. Windshield isn't defogging well.. do you like activated charcoal version or not?
for the startes with E34
http://www.black7er.com/downloads/mi...erwechseln.pdf
1995 540i Manual build 1/95
I'm already proficient at it, but others might benefit from your tutorial. The E34 is a bit unique! Was there supposed to be a link in your reply?
Actually, now that I've switched to a browser that will open a PDF, I see the instructions in the first link are for both 5 and 7-series cars. One thing I might add, at least on my 10/95 production car, I found it easier to remove the limit "switch" that sits toward the front of the car from the filter housing, just to get the wiring loom and those blue, white, and black connectors out of the way. Just press up on the lever and slide it out.
Activated charcoal? I didn't even know that exist... where do you buy it? That would get rid of 'crayon' smell in the car... and keep it smelling nice.
I wash mine every spring. I shake the dust off, spray it with the K&N filter cleaner stuff, let it sit a while then I rince it out with hot water. I inspect it to see if there are any rips or tears but none so far and it turns out like new and no bizarre smell...
Jeff
I prefer to be misunderstood rather than having to explain myself all the time...
I'll pay that... extra $10 for charcoal... better for our health and nicer smelling car.
What you need is evaporator cleaner stuff... I got extra over here... you fill up the evaporator. heater core with the whole can of foaming spray and have your AC on while you are doing this... eventually everything get washed out and nice smelling. This is best done in the spring or summer so the evaporator will catch water and wash out the foam detergent.
They want you to inject the evaporator area via the drain plug... I find whatever way I can to inject them in.
