That's not covered under warranty?
Hi guys, I've been searching parts stores, ebay, even checked Autohauz(Won't ship to Canada) and the rest are 180+.
I'm looking for the 02 Sensor for a 2005 Toyota Echo 4 door, it's the post/after catalytic convertor sensor I need.
Any idea's guys.
BMW E34 1992 525i Touring
you just won my vote for best thread title ever
When you use the OBD2 scanner... does the O2 read anything? If it is dead, it reads zero.
Rockauto.com has them for $48.
Alot of time, it is the MAF that is bad, not the O2 sensor. You need the scanner to make sure. Bad MAF triggers O2 sensor error.
Is it the post-cat 02, it's not the same as the front one, the second one is a lot longer.
MAF would trigger the first 02 sensor error, not the second.
I used a regular obdII scan tool, I'm going to try to get the Snap-on MT2500 onto it and go for a drive and see what we get.
Yes, downstream O2 sensor. You don't need special OBD2 scanner... as long you can read both of them... the first one is fast reading... number all the time. The second one is slow moving... you have to hold the accellerator for like 4 seconds or so before it change reading.
What error codes are you getting? MAF error will trigger O2 sensor error and like lean or rich fuel trim bank something.
I'm getting P0136: Oxygen Sensor Circuit Malfunction/high Voltage (Bank 1, Sensor 2)
Already got the info off mitchell on demand.
I was just really worried about it being the cat because the light has been coming on and off, on and off whenever it feels like, no real pattern, I need the scanner to read them, my friend has one so I'll do it this weekend if I don't just get the parts for rockauto
