[QUOTE=tim eh?
The main clues are whether the battery still loses charge overnight and..
***When cold the system charges fine... great ... 14.0V+ with absolutely every button pressed that can be pressed.... for the first 2-3 minutes...
then it drops off a cliff to below 12.0V and stays there. (temp guage has moved +/- 1/10th of it's range) I really have to turn everything off then to get the voltage back up but then I can run a medium load (lights, no defrost, heat on 2, radio) ok.
QUOTE]
Tim you summerized the essential here. I think that we may now trust both your new battery and alternator and you're right they should easily do the job properly.
Normaly such voltage drop could be signs of either bad cell within the battery (excluded now) or bad intermittent alternator voltage regulator (exclude too now). I would say that this major voltage drop (from 14 to 12 volts) is due to a heavy / abnormal load that suddenly appears from where ?? that's the question ! Or bad grounding (intermittent) in between negative battery pole and the alternator.
The starter connections does not look good at all, but your starter does it's job OK and is out of the circuit (received no current) when the car is running, i would forget about it.
Your A/C compressor has a electrical clutch that does'nt seems to engage, chances are that's because your A/C has loose it's gas in such a case a protection system / switch enable the compressor to operate (compressor protection), so the problem is not there.
Good idea to read the total load the battery have to drain when the car is running, so equiped you'll be able to see if it's really and extra load that the battery has to take after 2-3 min of normal operation (if not, it's only a volatge drop so the grounding system could be the culprit). But to do so easily that's a clamp on current meter that you would need.
Don't give up !
