Results 1 to 9 of 9
Thread: How do you start the car when you have a problem with the wires
    Apr 2008
    Belgium
    Default How do you start the car when you have a problem with the wires
    Hello,
    I can't start the car anymore. Contact lights work. But nothing when I want to crank the engine. I know it is electrical because I messed up something down in the dash.
    Can I start the car with a wire from the positive of the battery to the positive of the starter motor? Is it dangerous?
    What are the other ways to start the engine in order to troubleshoot problems?
    thx
    Aug 2008
    it's not necessarily the starter.... how is the battery voltage?
    edit- sorry, i shouldn't have posted... misunderstood your post.
    Oldham, England
    Quote Originally Posted by Mordan View Post
    Hello,
    thx
    This is a bit like asking 'can you help me steal a car please?':-) You already have a great big power lead from the battery to the starter. All the solenoid does is connect that lead to a down lead into the starter itself. So you can jumper the two terminals and the engine will crank regardless of whether you have a key in the ignition. What it wont do is power up your systems (DME etc) to enable you to get fuel and a spark to the engine. But if it does fire up at least you know where to look to fix it
    Apr 2008
    Belgium
    Quote Originally Posted by whiskychaser View Post
    battery is 12,45V... it is alarm related... I'm trying to steal my own car
    I have just read I can jumper ignition switch to solenoid
    but I prefer your solution.. so to recap
    to start my car
    1-put key in ignition switch
    2-jumper the + side of starter with small connector of solenoid
    3-the car starts and off you go.
    I hope my ****ed up alarm doesn't screw around with something else.
    if anyone has a picture of the + side of the starter and the connector of the solenoid to which I have to jumper, i would appreciate it errr my car would love her battery not to explode
    can I touch the jumper wire bare hands without dying?
    Actually, you can trigger the starter from the top... the round diagnostic plug... but don't know on your older model.
    Jumping #11(starter solenoid) & #14(12v)will turn the starter motor
    but will the ignition work?
    Quote Originally Posted by Ross View Post
    Apr 2008
    Belgium
    that is smart man! I see the #11 pin and #14 pin are the same on my 15 pins connector
    will the engine start if the ignition switch is in run position?
    by the way, on the 15pins connector, pin #15 is power supply for ignition
    I didn't look into which pin for ignition, if you say it's #15 then so be it.
    Either turn the key on or use a jumper for the ign also.
  1. Cold Start, CEL problem
    By guitarfish in forum 5 Series BMW
    Last Post: 08-23-2007, 02:05 AM
  2. Start problem bmw 525 tds (e34)
    By asse in forum 5 Series BMW
    Last Post: 10-26-2006, 12:37 PM
  3. 525 hot start problem
    By yaofeng in forum 5 Series BMW
    Last Post: 07-11-2006, 09:37 AM
  4. Hot Start Problem
    By LuF in forum 5 Series BMW
    Last Post: 08-25-2004, 04:28 PM
  5. Problem during start up
    By kentish in forum 5 Series BMW
    Last Post: 06-20-2004, 12:27 PM
