Thanks Andy, may call/txt if still stuck,costs will be met! Attacking the switch now.
Yeah, from what I remember, the diesels 'second' fusible link is that one in the e-box now I think about it. I'd definitely try using something to jump across the fusible links - especially the one near the battery
For peace of mind, the next thing I'd check is the back of the ignition switch with your multimeter - check that you're getting voltage actually sent to the fusebox.
Might be able to come lend a hand on sunday if you're around and still stuck
On US petrol cars the main battery cable comes through the firewall around the e-box. There is a terminal block there with several hot leads. Perhaps a loose or corroded connection there. ALSO the main cable has a "T" in it just inside the firewall, one side goes to said junction block, the other to the ign. switch as I recall. It would seem an unlikely failure but just so you know there is a joint there.
Thanks Ross, but do you mean the main battery cable or the Red main feed wire? The branch you mention, is it in the passenger compartment or the engine bay? If it goes to the ignition switch I assume it is the main feed wire.......
Main battery cable on our cars with the battery beneath the rear seat.
The branch is just inside the firewall I remember, behind the glove box. Not sure how all that goes in RHD cars.
#2 here, http://www.realoem.com/bmw/showparts...82&hg=12&fg=29
the junction is actually a tee covered in black plastic, one heavy cable in, one heavy one smaller out.
