check the area where the wiring is connected to the rear window first.
My stock radio reception seems to be failing especially on AM. Staions are geting harder to pick up and thre is often a popping noise on weak stations especially when I first turn on the radio. No difference when the engine is running.
Should I check the radio or the antenna amplifiers? I am at aloss to what to check or have checked. TIA
Nope Have not been in the dash area. Will check antenna/window connections.
Not sure what I should look for aon rear window connections. Removed sail panels and a couple connections on driver's side looked "weak". I cleaned all the connections and treated with a contact cleaner detoxit (sp). May have made a slight difference. Wiggled all connections while set on a weak AM station-no difference. Perhaps I should remove stock radio and clean antenna connections on radio.
I suspect the antenna booster is working, at some level, as I disconnected one of the coxaxal like cables and had no AM reception. Next step will be to pul the radio.
