Anyone ever replace their sway bar bushings? Would that help tighten up the suspension a bit?
I just may replace the bushings, starting with the front, just because. Does not look difficult. I assume Bentley has a procedure that works. Thanks
BTW, sway bar links frant/rear have been replaced.
I took the sway bar off recently to count it out of my clunk search! It was very very easy, 4 nuts to remove for the bushes and the two bottom nuts on the end links seemed easiest. You need to have the car on the gorund or on ramps though as jacking one side will cause problems!!!!
Tech works fornat and rear?
