Results 1 to 3 of 3
Thread: messed up turn signals
    Horsham PA
    Default messed up turn signals
    a couple weeks ago my turn signals just stopped working. The green arrow light or the click on the cluster wouldn't function when i moved the stalk up and down, nor would the actual signals flash. I checked the fuse and it was blown. replaced it, and all was well until two days ago when the turn signals completely died again. sure enough the fuse was blown, after i replaced it, it blew again within the first few uses of the turn signals. so i replaced it again and now only the left signal works and the right is on hiatus. the left has been working since, but the right is still dead.
    the fuse is still good so what could my problem be, i have no idea where to start looking. All the signal bulbs seem perfect if that makes a difference.
    Horsham PA
    i took apart the k16 flasher relay from the power distribution box and none of the wires seemed broken inside and the two relays inside weren't stuck, so i put the relay back in and now the right signal all of the sudden works. i don't know what i could have possibly done to fix it, but at least my signals are working. for now.
  1. Fast blinking turn signals front and back - weird?
    Last Post: 06-26-2010, 07:34 AM
  2. still can't get turn signals to work.
    By jjdickm in forum 5 Series BMW
    Last Post: 12-16-2007, 12:12 AM
  3. turn signals don't work
    Last Post: 11-18-2007, 04:30 PM
  4. lock car & flash turn signals?
    Last Post: 01-24-2007, 06:14 PM
  5. Clear side turn signals
    By hidenakka in forum 5 Series BMW
    Last Post: 12-01-2006, 11:46 AM
