I need to change tie rod ends and the link opposite the steering box. I see movement there. It started as a slight shake a month or two ago and is getting real bad. Any other places to check? Most other parts under there are fairly new. RF tire has a pretty bad sawtooth on the inner edge. I have adjustable camber plates and will probably set the camber at zero.
