Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: outer door handle gaskets E34, E32, E36, Z3 - NEW
    @t.wak
    2 sets for 4-door E34 sent out to Bulleen Victoria, Australia
    along with the special made toothed wheel/rim for the rear sunshade gear, made of steel instead of that weak plastic original stuff
    Aug 2005
    West Portland, OR
    @t.wak
    What is the rim for? My visor sometimes stays really stuck turned on if I turn it horizontally and try to turn it back after blocking the sun. What causes this? I just don't touch it, because I'm afraid one day I won't be able to get it to turn off.
    David
    set of door handle gaskets for 1997 E36 328i 4-dr sedan sent to Corvallis, OR
    thanks
    Yeaaah, OR!
    EuroLux:. Private Detail
    Charles,
    the toothed rim is for the gear of the rear sunshade, that toothed rim gets damaged over the years. See here the pics
    http://www.bimmernut.com/forum/swap-...-sunblind.html
    there is a small and a large gear part, my one is the large one as shown in the pics. When damaged, it usually starts to rattle and may not close or open completely, as part of the teeth are worn.
    Because the gear motor only switches off by increasing ampere, but it is designed to always run a few seconds longer to cope with different expansion of the sunshade mechanism due to heat, dirt etc, so these last few seconds damage the gear over the years.
    Best is you open the gear as shown in the link and have a look at it before you order it, maybe also different causes.
    Jan 2008
    Phoenix
    @h2ojo
    1x 4-door set shipped by airmail to Phoenix, Arizona
    thanks
    Got them really fast mail from japan, I think it less time then to get to something from New York lol. Thanks
    @Regal
    1 set for your E34 is in the way to TN, thanks
    I hope you are as happy as bleudyno, he asked me some time ago:
    Hi shogun, you got a lot of praise for you e34 door handle seals. Do you still sell them? The ebay ones are pieces of crap and don't fit right. You're set will fit perfectly right? Let me know and I'll paypal you. Thanks!
    2 weeks later after he ordered my ones:
    I received your package and installed them already. They fit like a glove! Thanks so much!
    @Keith: 2 sets 4-door sent to Brisbane, Queensland, Australia
    @dan:1 set for E34 540 sent to Moroga, CA
    @Joel: 4-door set is on the way to Beaverton, OR for your 1991 E34 M5
    @Rodolfo: 1 set for your E32 was sent to Curitiba - Paraná, 80240-010 Brazil
    @Franklin: 1 4-door set for your 93 E36 325i Sedan is on the way to NYC
    @Tyson:1 set for your E32 was sent to Cambridge, WI
    @Jonathon: 4-door set for your 1995 BMW 530i just sent out to VA ,
    @James:1 set for 4-door Sedan for your 1996 E36 328i were shipped out to MD
    @Dan: 1 set for your E32 740iL was just sent out FL
    @johnd: 2 sets for E34 are on the way to NSW, Australia
    @TechnoWeeny:1 4-door set for your E34 540 was sent to Logan Village, Australia
    @Alex:2-door set for your E36 was sent to PA
    @Marcus:1 set of outer doorhandles for your E36 Coupe is on the way to Berlin
    @James:Set 4 outer doorhandle gaskets for your 1991 E34 ///M5 is on the way to Jacksonville, FL
    @Robert: 1 set for your E34 540 shipped to WI
    @Steve:2-door set for E36 318ti shipped to San Antonio, TX
    @Rudolph: 2 sets for E34 are sent out to Germany
    @ Mike: 1 set for your 1998 E36 M3 Coupe sent to Middleton, WI
    @James: 2 doorhandle gaskets for your 1999 BMW Z3 M Coupe shipped to Huntsville, AL
    @Christopher: 1 set for E34 sent to Berlin, Germany
    @Ken, set for E36 Coupe right and left gaskets sent to Belgium
    @Phil: 1 set for E32 shipped to Newtown, Victoria, Australia
    Henry: 1 set for your E34 shipped to Woollahra, NSW, Australia, Comment by Henry: Hi Shogun, I understand you sell door handle gaskets for the E34 that fit? (I had a poor experience buying some on eBay that did not).
    @Paul: 2 sets for E34 M5 and E36 M3 4-door shipped to Egbert, Ontario
    @Christian: 1 x 2-door set for Z3 shipped to Hamburg, Germany
    @Paulo: 2-door set for your 1995 E36 328i Coupe shipped to Burnaby, Canada
    @Sascha: 4-door set for E32 750 shipped to München, Germany
    @Paul: 1 set outer doorhandle gaskets for your E34 shipped to Federal Way, WA
    @Manny: 4-door set for E32 shipped by airmail to VA
    @Ralf: 2-door set for E36 Cabrio shipped to NRW, Germany
    @Justin: 4-door outer doorhandle gasket set for your E36 M3 Sedan shipped to Savage, MN
    pics before and after on an E32 and the comment about the fitting of my gaskets http://www.bimmerboard.com/forums/posts/1267539
    @Flo: 1x 4-door set for your E34 Alpina B10 shipped to Ingostadt, Germany
    @Tim: 1 set for 2000 Z3 shipped to Edmonton, Canada
    Last edited by shogun; 06-07-2019 at 08:35 PM. Reason: shipping info merged over longer period
    @John: 1 set for E34 shipped to NE Kirkland, WA
    https://www.pic-upload.de/view-32379...skets.jpg.html
  1. Help: Outer door handle broken
    By bimmerred535i in forum 5 Series BMW
    Last Post: 07-10-2009, 08:43 PM
  2. sticking outer door handle?- solution
    Last Post: 01-10-2008, 01:33 AM
  3. outer door handle gaskets in U.K. for sale
    Last Post: 02-10-2006, 03:52 PM
  4. outer door handle gaskets in the U.K./Ebay
    Last Post: 02-09-2006, 10:16 PM
  5. I need to repalce the outer door handle surround, any tips?
    Last Post: 06-27-2004, 05:16 AM
