Thread: FS:Hella voltage regulator for Bosch alternators-new
    Default FS:Hella voltage regulator for Bosch alternators-new
    Hella Type 5DR 004 241-121, 14.1V, for 28mm slipring, for Bosch alternators only. Sample image http://www.auimg.com/bilder/002/500/b399.jpg
    OEM part 12311735742, 12311731908, 12311726022, Supersedes: 12321711399, Exchangeable retrospectively 12321279548,12311271664 http://www.realoem.com/bmw/enUS/part...&q=12311726022 This product fits 54 BMW vehicle variants.
    BMW 5 Series (E12,E28,E34,E39,E60,E61): 1 models, 12 variants between 1988 and 1993.BMW 7 Series (E23,E32,E38,E65,E66,F01,F02): 3 models, 27 variants between 1986 and 1994.
    BMW 8 Series (E31): 2 models, 15 variants between 1989 and 1995. like E31 850Ci/CSi, E32 750;735, 730 M30; E34 535, E34 530i M30
    Reference # OE for various car brands: 116 1005 0600 8, 116 1005 0600 811, 116 1005 0601 1, 119 1305 0600 0, 119 1305 0600 023, 119 1305 06023, 607 43997, 607 5201 6, 705 6840 0000 0, 705 6848 00000, 904 7100, 994 1761, 995 0116, 995 0612, 068 903 803, 068 903 803 B, J27 000 040 10, 1 271 664, 12 31 1 271 664, 5761.55
    Hella voltage 5DR 004 242-051 14.5V regulator, new, for BOSCH alternators only, Slipring OD: 14 mm
    fits for E36 320/323/325/328/E36 M3,Z3,E34 530/540/520/525, E32 740, E31 840 with BOSCH alternators.
    Fits as replacement for BMW # 1247892,1432964,1730604,1739365,1747920, 12311247892 ,12311432964,12311730604,12311739365,12311747920,1 2317739365,12311738351
    Also used on: Audi Quattro, Nissan Primera, VW Bus
    Audi/VW: 021 903 803B, 028 903 803B, 028 903 803C,Bosch: 1-197-311-212, 1-197-311-214 1-197-311-220,BMW: 1231 1247 892, 1231 1432 964, 1231 1730 604,Fendt F515900010010,Flat/Lancla: 2174825, 9944423, 9947103, 9950401,Iveco 42531176, 9950561, Magneti-Marelll: 940038014, Mercedes-Benz: 0021548502, 0331540706, ALTERNATOR: Bosch: 0-120-335-007, 0-120-465-008,
    in case you are not sure, please use www.realoem.com and select with your VIN the OEM part number to compare. Comes in original packing with installation instructions. Hella/Germany, made in China
    price: $45.00 shipped worldwide by SAL, not registered, not trackable, $50.00 shipped worldwide by air, registered. Paypal o.k., Shipping place: Japan
    Have several on stock. Contact me by email.
    Sample pic from the net http://s71.photobucket.com/albums/i1...rent=274_0.jpg
    @BigKriss: voltage regulator is on the way to Australia.
    @zmuff; was just sent out to VA, USA
    @ Dale Wood:was sent out to Ontario/Canada
    @erwin, just sent out yours for the E32 750 140A Bosch alternator to Austin, TX, yours could look like this one, from Nate's 750iL
    heres a pic of how bad mine was - new one from shogun was here in 3 days. thanks again -Nate
    http://i161.photobucket.com/albums/t...3/65caf33a.jpg
    @Alex: SHIPPED TO Pyrmont, NSW, Australia for E34 535.
    @Jim: 1 voltage regulator sent to San Diego for your E31 850
    @Scott: 1 voltage regulator for your Bosch alternator in E32 735 was sent out to Gaithersburg, MD
    @Azlan: 1 Hella voltage regulator typ 5DR 004 241-131 for your E32 735i with Bosch alternator was sent by EMS to Kajang, Selangor, Malaysia
    @Carl: 1 x voltage regulator for your E32 750 with Bosch alternator 140A was sent by air to Port Melbourne, Victoria, Australia
    @George: 1 x Hella voltage regulator Type 5DR 004 241-121, 14.1V, for 28mm slipring for Bosch alternators for your E31 1992 850ci - Hartge H8 6.0 conversion was shipped to London, U.K.
    @Joel: the Hella voltage regulator for your E34 525 has been sent out today by air, small packet to Hamburg, New York
    @Mike: 1 set ignition wires for M70 for your E32 750 plus a Hella voltage regulator Type 5DR 004 241-121, 14.1V, 28 mm, for Bosch alternators were just sent out to San Jose, CA.
    @Dan: 1 x Hella voltage regulator 5DR 004 241-121, 14.1V, for 28mm slipring for Bosch alternators for your E31 850 was sent to Huntsville, Alabama
    @bimmerd00d: Voltage regulator 5DR 004 242-051 for your E34 540 was sent to Austin, TX
    @Michael: 1 M70 voltage regulator for Bosch alternator for your E32 750iL was shipped out today to San Jose, CA
    @Joe: 1 x voltage regulator for Bosch alternator 140A for E32 750iL shipped to Stroudsburg, Pa.18360
    Last edited by shogun; 05-29-2016 at 08:21 PM. Reason: merged shipping info over a longer period
    minimum length of carbon brushes on alternator voltage regulator is 5mm.
    5mm = what stands out of the voltage regulator, here shown for the M30 engine http://workshop-manuals.com/bmw/5_se...ulator_switch/
    Check slip rings for wear, disassembling alternator and fine-grinding as well as polishing slip rings if necessary.
    Check for truth of running of slipring. Max. eccentricity for slip rings is 0.03 mm.
    http://workshop-manuals.com/bmw/5_se...h_alternator)/
    Disassembling and assembling Bosch alternator 90/115/150A
    http://workshop-manuals.com/bmw/5_se...90_115_140_a)/
    Replacing ball bearing Bosch alternator
    Replacing diode plate Bosch alternator
    Electric test on Bosch alternator
    http://workshop-manuals.com/bmw/5_se...ch_alternator/
    Replacing alternator belt pulley
    http://workshop-manuals.com/bmw/5_se...r_belt_pulley/
    Replace alternator belt pulley with overrunning clutch
    http://workshop-manuals.com/bmw/5_se...nning_clutch)/
    Got new Hella voltage regulators on stock for Bosch alternators (not VALEO), both versions, for version with slipring outer diameter 28mm and 14/16mm.
    @Wim: 1 x Hella voltage regulator for E32 750iL for Bosch alternator 0 120 468 072 to replace Bosch Voltage Regulator 1 197 311 038 shipped to Birmingham, AL
    @Serge: 1 28mm Hella voltage regulator for your M70 Bosch alternator shipped to Boca Raton, FL
  1. Bosch vs Valeo alternators
    By Wyn in forum 5 Series BMW
    Last Post: 02-07-2006, 11:37 PM
  2. Voltage regulator test.
    Last Post: 07-22-2005, 12:31 PM
  3. Voltage Regulator
    By jj7 in forum 5 Series BMW
    Last Post: 01-29-2005, 02:41 PM
  4. Voltage Regulator
    By freeparking in forum 5 Series BMW
    Last Post: 01-26-2005, 05:58 PM
