xi is the all wheel drive, the 330 is a 240mm clutch i can't remember for sure if the 2wd 325 is a 240 but theres a good chance it may be a 228mm clutch, you'd need a flywheel to go with the big clutch to use it. on a different note these clutches suck big time and a major piece of **** design, just had one come back through my shop that only lasted a year before failing, to avoid a repeat i installed a different set up from a e36 m3, clutch kit and flywheel drop right in and are not that goofy self adjusting design that the e46 uses
