Thread: Hot air blowing only from vents. Is this a common problem?
    Default Hot air blowing only from vents. Is this a common problem?
    Hi,
    I have a 1995 530i/5sp manual. When I turned on my fan, only very hot air came out. Is this a common problem?
    Thanks in advance.
    1995 BMW E34 530i/5sp
    Laplace, LA
    Quote Originally Posted by Badshift
    Hi,
    Thanks in advance.
    Although my compressor is completely shot, I have the same problem.
    90 525I
    Melbourne, Australia
    Faulty heater valve seems to be a common fault - it is solenoid operated and if it sticks in open or 'on' position then you get hot air even when you don't want it. The valve is attached to the heater water hoses in engine compartment, near the fire wall. You should here or feel the valve solenoid operate when heating is selected. Sometimes the valve parts seize up inside and can be loosened up (you need to remove it) to get it working again.
    Laplace, LA
    Default Thanks. I'll try that. Is it a difficult job?
    Quote Originally Posted by bill g
    Default Heater water valves
    It's a commom problem on E34 and E32s. Try this link for the fix
    http://www.users.qwest.net/~gbower/b...eatervalve.htm
    hope this helps
    Phil
    Williamsburg VA, USA
    Default Just had this problem ...
    I was able to free up the valves by lightly but smartly tapping them with a long 3/8" extention and a large adjustable wrench(they were handy). I read somewhere that it worked for someone else. Next time it would be the first thing I try and I'm sure it won't work then.
    Karl
    Hi,
    Thanks in advance.
  1. Cabin vents keep blowing....
    By patznu in forum 5 Series BMW
    Last Post: 07-12-2007, 03:05 PM
  2. cold winter air blowing to back seat vents
    By gymkata in forum 5 Series BMW
    Last Post: 02-12-2007, 10:17 AM
  3. a/c problem...rear lower vent blowing hot air
    By Anthony 94 525i in forum 5 Series BMW
    Last Post: 05-06-2004, 04:56 PM
  4. Replies: 4
    Last Post: 04-28-2004, 06:11 PM
