for most deusche bags, but if you work on the car it's cheaper than car payments
Remeber you're buying a 13 ++ year old car....
everything
-Mike
I dont know if this is entirely true...
Around town the 520's tend to be more economical than the diesels - a mate of mine owns both a 520 and a 525tds. This is because around town, if you've got even a slightly heavy foot, the tds engine is constantly on the turbo...
Highway/motorway is entirely different though - at 60-70mph the diesel is barely ticking over due to the gearing, 80 it sits lower than my 540 at just 2krpm a la:
If you've got long, steady speed commutes to do - a diesel wins hands down at 600+ miles per tank, if you've got a short commute 540 all the way who cares if you only get 250 miles a tank when you're doing less than 100 miles a week XD
The 525/540 argument I'm not so sure about either, my 525iA used to get at least 22 around town on my commute to work - the 540iM gets just 16-17 on the same route
BE WARNED: Diesels are not cheap to fix due to the rarity of this engine even in this country - however, shockingly, you can get TDS engine parts from landrover for cheaper than bmw. The 90/00's range rover diesel used the same engine.
The 520i also tends to be more reliable than the 525i with regards to head gasket/cooling problems... the 520 head is quite a lot thicker than the 525i head and less prone to warpage/cracking in an overheat.
First thing you do with an M50 engine on purchase is change the water pump out - or this happens:
Inspect the radiator with a fine tooth comb as well - check for the usual furring associated with coolant leaks, if there is any it's likely the previous owner has used a can of radweld, and that's all that's holding the radiator together. The incident in the above photo proved that quite well!
Oh, finally - the 520 may be more reliable than the 525, but the 525 has a different loom and dashboard in it - it has more toys to play with and can easily be retrofitted with a complete OBC system.
You pays your money and you makes your choices!
my reply,
a)the missus is now trying to convince me to get a newer car (E39) on finance so we dont have to pay out on repairs all the time
b)im thinking that 5k loan, paying 140 quidf a month for 3 years for an E39 is a lot more than buying a sub £1000 E34 and paying out a few quid here and there for new bushes and a water pump.
c)can u guys give examples of ur last 12 months of expenses on your E34?
d)540 comment, I'd love to...im tempted, (after all i never do more than 500 miles a month, usually less than 150) im especially tempted by a 535i E39 ive seen.
Sig car has gone, but buying an E34 on my return to Britain in 3 months
Where to start...a)the missus is now trying to convince me to get a newer car (E39) on finance so we dont have to pay out on repairs all the time
a) the E39 will feel better overall as a 'posh' car with a bit of go (if 540). Else, I don't feel it would have outlasted my E34. Everything electrical will eventually just die.
b) loans are bad. You won't find a more comfortable/comforting car as a well kept E34 for that money. It's got so much ahead of it's time.
c) nope. I forgot.
d) 535i E39? I want to see this unicorn...
Bottom line, the missus will probably want the E39 just because it SEEMS more modern. Frankly, the E34 is built so much tougher. It'll age much better than an E39 unless you buy 2002-2003 gen. Then the $$ spread is so much it's not worth it.
I'm rambling.
d)
http://cgi.ebay.co.uk/2001-BMW-535I-...d=p3286.c0.m14
http://cgi.ebay.co.uk/STUNNING-BMW-5...d=p3286.c0.m14
Ill carry on doing my reserch but i can see me getting a 525,or a 540.....but as much as id love a V8 the higher costs involved may be a bit too much. 90% of the journeys i do will be costant speed journeys though,like sticking at 60MPH for long periods...but could i do with that a V8 under the bonnet??? i'd be flooring it just to hear the noise. what BHP does the 540 E34 have?
the e34 540 is about 210 kw as rated by BMW.Paying interest on a 5 k loan instead of a 1k carplus a few costs.From the finance point of view there isnt a contest there.If i was you i would go for a later 525...
Gone but not forgotten
