4: Remove the gearbox
Now comes the fun part, getting the gearbox out.
The 6 speed is the heaviest of the bunch, but only weighs in at 46kilos (101.4 pounds), so isnt that heavy, one guy can lift it easily. Two make mincemeat out of it.
It can be done one of two ways, the first being preferable:
Two people:
- Remove the remaining bolts, the clutch will easily support the weight of the box
- Get one person under the front of the box, one under the back and a jack supporting the middle of the box
- Slide the box backwards slowly and let the weight rest on the jack for a moment
- Both lift the box, kick the jack out of the way and lower it to the ground slowly, being careful not to drop it onto the drain plug
One Person:
I've tried this - if you're really short of something decent to place the box on for support you can lower the box carefully onto yourself by bracing the bellhousing on your knees and 'bench pressing' the back end of the box down onto your chest. Here's the trick - the drain plug sticks out significantly, you either need to pad it or make sure you're not gonna puncture yourself with it somehow!
I would NOT advise doing this if you're a small person, but if you've got some strength, this may be the easiest way to get the box out. Watch out you dont drop the bellhousing end of the box though - it'll be extremely painful!
Make sure there's some cardboard or the like under it, and drag the box out from under the car. You may need to raise the car slightly to do this though.
5: Removing the clutch
WEAR GOGGLES OR SUNGLASSES WHILE REMOVING THE CLUTCH
I didnt and ended up scratching my eyes to sh!t, a *lot* of crap will fall out of the clutch as you take it apart and you're directly under it.
Once you've got the box off and out of the car, you can remove the clutch plate
- From underneath you'll need an 8mm hex drive
- Gradually, working in a circular rotation unbolt the retaining bolts around the outside edge of the flywheel
- If your clutch has any life left in it, the pressure plate should easily push itself off the flywheel... mine didnt!
- If your clutch is at the end of its life (like mine) you'll have to very carefully lever the pressure plate off the flywheel with a blunt object - again do this in a circular manner to avoid wedging it solid.
- The pressure plate is damned heavy, dont smash yourself in the face with it when it does come off
- Extract the clutch plate and remove from under the car, the plate should be a minimum of 7.5mm thick (- thanks stilljester)
- You're now ready to remove the flywheel, you need an extended T50 (-not T60 as stated everywhere, Ross) torx driver to do this and something to lock the crank with - again this is damn heavy
- Breaker bars at the ready - these bolts will be in hard!
I'd advise changing the crank rear seal while you're at it, I've not had a go yet but apparently it's easy on the V8 as you dont have to pull the sump.
