Results 1 to 8 of 8
Thread: ABS kicks on at low RPMS
    Apr 2004
    DFW
    Default ABS kicks on too much
    My ABS light comes on and stays on and my ABS kicks in very often when I'm braking...more often than not.
    Its annoying more than anything and I'm concerned its a safety hazard. What could be wrong?
    also RIP www.bmwe34.net :( :( :(
    What happened to it?
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by misfortune View Post
    try to clean your abs sensors might just be dirty if still the same you might need to hook it up to the computer to know why ABS is triggering a fault. but usually its just the sensors
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Wellington,New Zealand
    do you run a staggered or non std tyre/wheel set up?
    Gone but not forgotten
    Apr 2004
    DFW
    Quote Originally Posted by Paul in NZ View Post
    17" style 42s 245/35/17 I think. Whatever comes stock on the e39
    Possible your brake switch is bad...
    your signature then is rather misleading!
    Apr 2004
    DFW
    Its an e34. I just have e39 wheels on it.
    Jun 2006
    Wisconsin
    In addition to cleaning the ABS sensors, you also might want to check the sensor leads - especially on the front wheels as they're subject to flexing when the car is steered and can develop internal breaks due to metal fatigue. Connect an ohmmeter to the pins in the connector and flex the lead up and down its length. If the ohmmeter spikes, you've found a fault. A pretty good Mercedes tech told me he ran into this problem fairly often in cars 10 years and older.
  1. 95 525i shutters and loses power at 2500 rpms to 3000 rpms
    By caqueenslace in forum 5 Series BMW
    Last Post: 04-16-2009, 07:41 AM
  2. Dumb question: How to know when ABS kicks in
    Last Post: 08-16-2006, 04:21 AM
  3. Help...rev limit kicks in @ 4000
    By Robmczzz in forum 5 Series BMW
    Last Post: 11-15-2004, 03:21 PM
