Originally Posted by
J.DeFeo
Tell me if this makes sense:
There are two weights on the front halfshaft. There's one on the rear halfshaft. A weight indicates a heavy spot on the opposite side. Would it make sense to assemble the shaft in such a way that the heavy spots and weights are opposite each other? E.g., try to find the approximate center of the two weights on the front shaft then orient the rear shaft in such a way that the weight on the front shaft is aligned directly opposite that center point.
If you have disassembled the driveshaft without marking it you have two choices:
Bring it to a drive shaft shop for a rebalance
OR
Start for instance in the orientation you've picked above; reassemble & install, drive the car noting the vibration. Then remove the driveshaft and change the orientation anywhere from 2 -10 deg depending on how bad it vibrated. Repeat until smooth..
1992 525i Touring M50 5spd Manual 230k+ miles - SOLD:-(
