Some of you probably remember my spark plug & oil burning problem... Taking the advice I was given from original thread given I decided to bite the bullet and ordered:
- fuel injectors
- gasket kit
- valve seals
- head bolt let
A friend is coming by in a few weeks and were going to get it all installed.
Meanwhile, the problem is getting worse... I used to only burn oil when the car first started... Now i'm burning oil while driving. Clouds of smoke pour out the exhaust as I rev the engine. I'm having to add half a quart of oil every 3 days on my ~50 mile trip to work and back. Something is very wrong.
Trouble is... I'm not so sure the replacements are going to fix my problem. It sounds more like bad piston rings right?
I did compression tests a little while back and got results of ~190 on about all cylinders except for one at 178 or something.
Quick reference to what my spark plugs look like after a while... Spark plugs 1-4 foul up very bad. The rest do too eventually, but manage to stay a bit cleaner.
http://www.buysmartpc.com/temp2/plugs/4.JPG
http://www.buysmartpc.com/temp2/plugs/3.JPG
What do I do?
Continue with the replacements? Or is it time to start to look for a new m20? Possibly a new E34...
