Results 1 to 10 of 12
Thread: strut mounts fukced?
    Montreal, Canada
    Default strut mounts fukced?
    this on my car:
    is popped up a bit on the passenger side compared to the driver side.
    and it moves up and down a bit when i bounce the car...
    what's ****ed exactly and is it dangerous to drive with it like that.... not that I have a choice anyways...
    Quote Originally Posted by Monastie
    this on my car:
    Well, I've never seen a strut mount do what you describe, but I won't doubt it for a second. Unless the (3X13mm?) nuts that secure it to the body are loose, then yes your strut mount is FUBAR and needs to go.
    It consists of rubber and a bearing, so take your pick on which is causing all the play. Now is the time to think about suspension maintenance/upgrades, as the entire strut assembly and spring must be removed to replace the mounts. Oh, and do both, as the other side isn't far behind.
    Dave
    Montreal, Canada
    actually I just changed the front suspension for bavauto springs and bilstein sports shocks
    Feb 2007
    New Forest, ,UK,
    If the centre nut is the thing moving then chances are that when somebody replaced the springs they did not do the nut up tight enough. If the three 13mm nuts are moving then tighten them! The bearing/rubber does fail but it should have been obvious when the springs were changed, given aset of spring compressors its no bug deal to replace, search the forum for "how to"
    Then you forgot to put back the conical washer that sits on the strut shaft and before the upper strut mount.
    Bay Area, CA
    Sounds like your drivers strut bearing has failed. I would not drive like that or the strut top could puncture or dent your hood on a tall bump.
    You can buy a new strut bearing but you are supposed to change both sides when you replaced your shocks.
    Greg Mannino
    Dec 2006
    it happened on my car. It needs to be replaced.
    Montreal, Canada
    well its fixed... most overpriced fix ever but I needed the car quick
    Dec 2006
    where did you go?
    Montreal, Canada
    A garage on cote-vertu in front of the jean-coutu called garage rony.
    sourcing them was a pain... so I could only use the parts he found, since the ones autoelectra had gave me were the wrong ones.
    ended up with a 663$ bill concluding very badly a very bad week.
  1. Need strut mounts for my 5
    Last Post: 03-24-2010, 08:43 PM
  2. ? about 89 535i strut mounts
    By bulldog_shotgun in forum 5 Series BMW
    Last Post: 02-15-2007, 06:14 PM
  3. Do strut mounts need to be changed?
    By bfd in forum 5 Series BMW
    Last Post: 08-21-2006, 04:06 PM
  4. strut mounts
    By Felixdacat in forum 5 Series BMW
    Last Post: 03-05-2006, 08:16 AM
  5. Are e30 and e34 strut mounts the same?
    Last Post: 02-08-2006, 09:25 AM
