Results 1 to 3 of 3
Thread: 740i won't start
    May 2008
    Default 740i won't start
    I have an E38 (production date 11/94). The vehicle was running, then turned off and sat for several months until the battery died. Now with a full charged battery, the engine spins but will not fire. The fuel pump activates with 100ish psi. I replaced the crank shaft sensor and changed spark plugs. When starter fluid is introduced after the mass airflow sensor, the vehicle does not fire. I also disconnected the + and - from the battery and held them together (no battery) for 20 seconds as recommended by a BMW tech to 'reset' the system. This didn't help. Does this vehicle have an EWS anti-theft system and could that be the problem?
    Any suggestions would be appreciated.
    Apr 2008
    Illinois
    Try disconnecting the battery, first remove the - then + for at least 30 minutes.
  1. 1995 740i - 4.4L or 4.0?
    By rcbrown23 in forum 7 Series BMW
    Last Post: 09-21-2007, 11:47 PM
  2. My 740i go crunch.
    Last Post: 05-10-2007, 11:38 AM
  3. Is this a good buy? 95 740i.
    By thedivision in forum 7 Series BMW
    Last Post: 07-14-2006, 11:22 AM
  4. Considering 1999 740i
    By Al Gray in forum 5 Series BMW
    Last Post: 09-26-2005, 01:34 AM
  5. Last year for 740i with Nik block
    By willobmw in forum 7 Series BMW
    Last Post: 12-29-2004, 12:38 AM
