Sheared the oil change nut off when changing the oil to go to a local BMW event
Pulled off the oil pan and there were two bolts in the pan. Of course I'm freaking out, but after taking a close look around, it appears that only one of the oil pump bolts is out, so where did the other bolt come from?
All of the bolts are accounted for on the accessible parts of the engine from under the car, to about 6" up or so.
The bolt is 1 1/2" and the head is 10mm. Writing on the head says, "Kamax 88"
