Results 1 to 7 of 7
Thread: Combustion Chamber Cleaning
    Mar 2008
    Default Combustion Chamber Cleaning
    There are a bunch of methods for removing carbon deposits in your engine. Here is one that looks interesting:
    http://www.bmw4life.com/ping.htm
    I dont know how I feel about sucking water into my engine... you?
    1995 540i/a 145k
    Houston, Tx
    3M Fuel system cleaner .. the one that you have to attach to the fuel rail and run the engine off of (unplugging the fuel pump relay) works very very well. The whole "water doesn't compress" thing does work, but M60/M62's are too expensive to replace in a worst case scenario.
    "Scarlet" `97 540/6 with sleepy mods.
    "Box Car" '87 535isA - Old School Charm, new school Flair
    Sounds okay to me, lots of fans of Seafoam around too. Plain water will also remove some carbon deposits.
    Jan 2007
    San Jose, CA
    I always just put a hose on a light, but wide spray pattern and kept the engine revved up a bit while I sprayed it into the venturi at the front of the AFM. I know some guys use transmission fluid, but I wonder what that does to the catalytic converter.
    Dec 2006
    seafoam works very, very well. Have yet to use it on my bimmer, but used it on my other cars and it's great.
    Sep 2007
    Seattle, WA
    Agree on the Seafoam use. Works better than anything else I've ever tried.
    Mar 2004
    NSW, Australia
    well it goes inside the combustion chamber and evaporates with the gasses, as long as youre not pouring bucket loads of water in!!
  1. engine cleaning - no steam cleaning!
    Last Post: 03-09-2009, 08:23 AM
  2. video-internal-combustion-engine
    Last Post: 11-26-2006, 05:27 AM
  3. Cleaning combustion chamber
    By jaz525i in forum 5 Series BMW
    Last Post: 03-01-2006, 10:45 AM
  4. Some carbon buildup, combustion chamber cleaning info
    By Lennyz525i in forum 5 Series BMW
    Last Post: 02-26-2006, 07:59 PM
  5. Combustion gas in the cooling system?
    Last Post: 05-20-2004, 09:45 AM
