On the UK 520iSE you get this oddments tray.
Cheers,
Shaun M
Hi All,
I've just installed a rear centre console vent kit to my car. If anyone is interested in this mod (some UK owners perhaps?) then I could post a quick descriptive & post some helpful pics too!
Cheers,
Shaun M
Cheers,
Shaun M
Here's a pic of my new vents. Not so easy to install I like them better than the tray that was there before.
It's also a good pic showing off my OBC & digital dash retrofit, and my shorter than short gearshift!
Cheers,
Shaun M
:o
Are the 520i's not fitted with rear vents as standard? Just a blanking plate or something?
Are they working?
You can also get a plate with lighter for the one under your vents..
I got it, but theres no cables for it when its a e34 without it from original. So mine is there but not working..
Hah Dave! Tranny mounts are spot on bud - I cut that E30 shift as short as humanly possible, giving the short gearshift & short throw - I love it!
ATB,
Shaun M
Yes they work just fine, after I knocked out the baffles under the air fan blower box thingy. I could fit a rear lighter socket and solder/splice some suitable guage cable from the front socket wires. This will give two sockets protected by 1 fuse. Shouldn't be a problem if using only low power items (chargers, sat nav etc).
Cheers,
Shaun M
The knobbly bit? It's the controller for the Sony head unit.
HTH,
Shaun M
Looks like you need new transmission mounts, droopy droorsalso a good pic showing off my OBC & digital dash retrofit, and my shorter than short gearshift!
Nice jb on the vents,
Dave
I did this and put in an inline off switch so it does not drain juice when I am parked for a few days at a time. Just takes some skill with a Dremel tool to get the hole perfect and then I Krazy glued it all in place.
