Results 1 to 10 of 14
Thread: Replacing transmission fluid and filter.
    Mar 2008
    NY
    Default Replacing transmission fluid and filter.
    I'd like to do it because I do not have the history of service yet. Is it recommended?
    Has anyone done it themselves and what does it entail?
    I'd like to find a Bentley Manual so I can start to do more work myself.
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    2000 Harley Davidson Softail
    2004 Ford Expedition
    Read this acticle on changing A/T fluid and filter. It'll give you an idea of what it entail. I've sucessfully done it on my 92 525, I went as far as flushing the entire transmission, with this you'll need helpers. I'm currently working to do the fluid and filter change on my 95 530.
    Here is the acticle by Pelican Parts - http://www.pelicanparts.com/bmw/tech...Fluid_Auto.htm
    Honolulu
    Quote Originally Posted by glen-sj
    90 535 should be way easier....drian plug, one pan and a dip stick
    dont flush it, just the pan and filter, repeat a couple times a year and you shouldnt have any probs
    95 E34 530I V2.31
    Feb 2005
    Geneseo, Illinois
    Quote Originally Posted by vping
    Just don't be like me and break off one of the pan gasket bolts. Then try to use a bit extractor, then break that off in there. After that, Drilled it out with a drill bit (which barely worked) then break the bit off in there! Yep, I drilled a new hole, and put the clamp on right next to it It works and has no leaks! besides setting me back a few days without my car and completely freaking me out in the process! Other than that, its easy lol
    -Pat
    89 535i
    83 528e
    82 Yamaha 650 Seca Turbo
    1981 Honda CB750C
    Maryland, Virginia, D.C.
    That's quite a story.
    Feb 2005
    Geneseo, Illinois
    [QUOTE=ThoreauHD]That's quite a story.
    lol ya, wasn't fun, very nerve racking. An experience none the less. More like a horror story.
    89 535i
    83 528e
    1981 Honda CB750C
    Jun 2006
    Bethesda, MD
    I've gotta get on this job asap, no clue when my transmission fluid was last changed. Any recommendations on what type of fluid to use? I'm not going to flush, just drain from the plug. I fear a flush would destroy my tranny.
    Heres a stupid question but i've gotta ask, how do you refill the fluid? Dipstick tube seems to be the only way unless i'm totally missing something...
    Honolulu
    Dip stick is the easiest.....new ones don't have 'em and that's more fun to fill.
  1. Changing Transmission Filter/Fluid
    By vping in forum 5 Series BMW
    Last Post: 01-06-2009, 02:42 PM
  2. replacing fuel filter DIY
    Last Post: 04-19-2007, 09:36 AM
  3. Need Help replacing Fuel Filter
    By brendanm in forum 5 Series BMW
    Last Post: 01-24-2007, 03:28 PM
  4. Replacing the micro filter in an E36 3 Series
    Last Post: 07-14-2006, 02:56 AM
  5. Replies: 0
    Last Post: 04-18-2006, 05:56 PM
