Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Shaking while at freeway speeds
    Default Shaking while at freeway speeds
    Right about 50 miles be hour the steering wheel begins to shack a little and the front suspension starts to shake. I have replaced the 2 tie rod ends and got my wheels balanced but that just seem to make it a little worse. I ordered the center tie-rod, well I didn't know their was a center one, hopefully that helps, but could it be anything else?
    Typically it is the thrust arms that needs to be replaced. Alot of topics on this one. M5 bushing is the best and longest lasting... 750iL bushing is the typical upgrade. Lemforder is the best thrust arm to buy, Meyle is second.
    Dec 2005
    Nashville, TN
    Do a search for "shimmy" here and on the other boards. You'll turn up *loads* of information.
    1995 525iM - 131k - Alternator play, broken s-belt
    1995 525iA - 147k - Tensioner weirdness, broken s-belt
    2001 Intgra GS-R - 130k - spun bearing
    2002 Honda Odyssey - 80k - fragged transmission
    I undestand a shimmy is the suspension shaking, but my steering wheel is shaking as well.
    the suspension shakes and you feel it through the steering wheel. tiger is right on the money.
    Houston, Tx
    If you want to "upgrade" from the liquid filled stock ones, just ask for the thrust arm bushings from a 95 850i, they go right in and are solid .. they work great
    "Scarlet" `97 540/6 with sleepy mods.
    "Box Car" '87 535isA - Old School Charm, new school Flair
    are you running these? because I've never heard of them before.
    Quote Originally Posted by SnakeyesTx
    Houston, Tx
    I *was* running these till my car was totalled about 3 weeks ago
    BMW 750i bushings: 31 12 1 136 607 (same as the 850i)
    Got the original idea from bmwe34.net ..
    Mar 2004
    Quote Originally Posted by BigKriss
    Tiger is right on the money - lemforder and M5 - I found out the hard way.
    07 525i 22K, 07 328xi (41K)
    so are the trust arms the lower or upper control arms?
  1. Smashed on the Freeway - Lower front end repair
    By randoms in forum 5 Series BMW
    Last Post: 01-04-2011, 10:40 PM
  2. Egged! on the freeway?
    By BennyM in forum 5 Series BMW
    Last Post: 04-09-2010, 09:36 PM
  3. Fix for: Overheating in traffic/Ok on freeway
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 12-15-2008, 02:23 AM
  4. Air con blows cold only on freeway.
    Last Post: 08-22-2007, 07:50 PM
  5. Abandoned E34 on freeway, anybodys car?
    Last Post: 02-20-2007, 06:57 PM
