On the sequence of displays you'd like to see. If, for instance, you want time, then date, then temp, then AVG MPG, then AVG SPD, then you'd hit them in that order using the OBC, so that it will cycle through them in that order when you depress the turn indicator stalk. I think it mentions it in the owner's manual somewhere.Originally Posted by Dan in NZ
Or, I could be way off base...anyone else wanna chime in?
Bill B.
