Originally Posted by
jstew4u
replaced cylinder head after timing belt skip... replaced punched thru piston
all rings ...cleaned piston...honed cylinders...remanufactured head had crack in water jacker/ oil galley...got replacement. torqued to 22ft then two stages of 90 degrees in correct pattern. motor ran perfect with cracked head..but overheated. Now with new head ..motor will not stay running ..will rev to redline on startup for no reason...sputters..like it is missing,???
fuel injection? o2? I'm and idiot?
1500 dollars later im still in the dark here.. any help would be appreciated..
thanxxxxx,
James.. 90' five and a quarter. island green. M20 powerplant
