Results 1 to 10 of 15
Thread: brake lining warning!
    East Brunswick, New Jersey
    Pull the sensor connector. Short it (the car side, not the sensor side) with a piece of hard wire. See if the symptom occurs.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Feb 2007
    GreenHills East-Philippines
    Default brake lining warning!
    whatsup guys! been a long time since i last posted i Just change my brake pads front and rear with the brake wear sensor but now still im having brake lining in the OBC. this is what i noticed when i turn my wheel in full lock to the right all is normal but when i put it in center or turn it to the left *bing* brake lining! i change the front sensor for the 2nd time still the same. I visually checked everything, it looks normal and nothing is broken or out of place. any idea guys thanks
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Sep 2007
    Melb, Australia
    There's a rear brake pad sensor isn't there? Change that?
    Ken, from Melbourne AUS.
    '89 535iA with a 5 speed swap.
    Feb 2007
    Quote Originally Posted by Ken35i
    yup i did. it's the front thats having problems when i turn the wheel full lock on the right no brake lining msg. in the obc
    Quote Originally Posted by JD525IA
    Why did BMW decide to put sensors on just the left front and right rear brakes? Why not all four?
    JD
    Why double the trouble?
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Oldham, England
    Quote Originally Posted by bmwrp8
    Check round the back of the lead where is runs past the strut. Mine had worn through - any more and the circuit would have been cut. Result: brake lining warning. Would account for the 'now you see me, now you dont' warning
    Mar 2004
    Phoenix, AZ
    Default Yep - I've got that too!
    I took my car to the self-serve wash Friday and blasted my wheels to get the brake dust off and to remove some bugs that had overstayed their welcome.
    When I started off again and got about 5 miles down the road, I got the Brake Linings message. The brake pads aren't that old. This weekend I'm going to give it a peek, but I bet I find a wire broken or something like that.
    JD
    Minneapolis, MN. USA
    I had a problem with the warning coming on too, then I realized that there is a connector in the passenger rear right by the place that you would place a jack stand. I noticed it was loose, so I unplugged it, made sure it was clean and plugged it back in again, that fixed my problem with the sensor entirely!
    I would figure that all you need is one sensor in the rear and one in the front, if your brakes are working right, both the left and right sides of the car will wear evenly and there is no need for a secondary sensor in that area.
    Good luck, hope this helps!
    (OO ( )( ) OO)
    1995 BMW 540i
    Minneapolis Bimmer Group Founder
    Feb 2007
    Quote Originally Posted by whiskychaser
    found the problem! when i had my suspension serviced they left my brake assembly hanging with only a piece of wire to support it. the wire that connects to the sensor was stretched and probably cut inside. thanks for d reply guys
    "found the problem! when i had my suspension serviced they left my brake assembly hanging with only a piece of wire to support it. the wire that connects to the sensor was stretched and probably cut inside. thanks for d reply guys"
    I suspect that piece of wire WAS your sensor wire
  1. Replies: 4
    Last Post: 12-31-2008, 10:41 AM
  2. brake lining warning circuit wiring
    Last Post: 06-23-2008, 09:57 PM
  3. Brake Lining Warning - Reset?
    By AutoXr in forum 5 Series BMW
    Last Post: 04-25-2007, 03:21 PM
  4. 525iX - Brake Lining Warning Light
    By 525iX - yes X in forum 5 Series BMW
    Last Post: 04-26-2006, 06:21 PM
  5. Brake Lining warning relief
    By rot535i in forum 5 Series BMW
    Last Post: 02-04-2006, 02:10 PM
