May have a blown bulb. I think it's as simple as un-screwing the socket from behind the lenze.
Help Please,
My 1995 525I BMW left turning signal doesn't work but the right it does. I noticed when I had the lights on during the nite the turning signal light were on too but when I turn the left signal on it won't blinks.
Thank you for your help.
Ken, from Melbourne AUS.
'89 535iA with a 5 speed swap.
Could be a bad ground. Put side lights, hazards, indicators and brake lights on at once. If it lights up like a xmas tree you have your answerOriginally Posted by min_772000
My hazards light doesn't work either. I had changed all light bulbs and still my left trunig lights does work. Does the right and left signals use the same relay? Why the right signal works? ut not the left.
Most likely this is corrosion in one of the bulb sockets or connector.
How do I check for short in my wiring?
i cleaned out some corrosion in my e28's sockets and it got the rear taillights to work. Just take it out and scrape it and wash it out.
1989 11/88, M30B35 175k-miles 535iM
1988 04/87, M20B27 153k-miles 528e
1987 01/87, M30B34 126k-miles L6
Washington D.C
I would borrow a flasher can and test again. They are double relay type one for left and one the right.
You will find your flasher can in the fuse area under hood turn on the working turn signal and follow the noise!
regards fred
I did turn on the right signal which it works and yes find the relay. when I turn on the left signal which that doesn't work there was no noice come out of the relay. Does both signals work off one relay?Originally Posted by Fred Tyler
