Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Ticking noise, increasing with speed, unchanged by neutral gear or braking...?
    Aug 2005
    West Portland, OR
    Default Ticking noise, increasing with speed, unchanged by neutral gear or braking...?
    Recently I have been encountering an intermittent, loud ticking noise coming from outside of the car. It increases with speed, as if hitting the wheel, sounds similar to a credit card in the spokes of a bicycle. Also, it goes unchanged by putting the car into neutral while driving, even when the revs go down, it stays constant with the wheels spinning, and slows down as the car itself slows down.
    Lastly, it's not affected by braking, so I don't know if that would be a stuck caliper if this were to be happening.
    Regardless, I have no idea - all options are open, I just need someplace to start, because I can't see anything stuck or that could be rubbing anywhere...
    Thanks guys!
    EuroLux:. Private Detail
    Jan 2008
    Quebec, Canada
    -Heat Shield behind the rotors
    -Rock BETWEEN heat shield and Rotor
    BMW E34 1992 525i Touring
    Aug 2005
    West Portland, OR
    Quote Originally Posted by bad_manners_god
    Thanks, I'll check that out - think I'll have to take it apart to get back there?
    You've got quite an array of vents on your 5er there.
    Apr 2008
    Washington DC
    I also have a weird ticking noise...well, more like a loud clanking noise when I have the car at idle. It seems to be coming from the rear.
    I've had a minor ticking noise coming from one of my wheels, but I somehow managed to fix that when my rotors were replaced.
    1989 11/88, M30B35 175k-miles 535iM
    1988 04/87, M20B27 153k-miles 528e
    1987 01/87, M30B34 126k-miles L6
    Washington D.C
    Jan 2008
    Quebec, Canada
    Quote Originally Posted by CharlesAFerg
    No need, turn your wheels all the way to one side and then spin them, if it's some sort of metalltic rubbing sound then:
    a.) Something it rubbing on your rotors
    b.) Your caliper bushings need greasing
    c.) Your pads need cleaning
    El Paso TX
    guibo fraying
    the pad sensor has come loose and is hitting the spokes? ( happened to me once)
    Apr 2008
    Washington DC
    In my case, i hear a random clunk at idle from the guibo, and can distinguish that sound, but the other clunking is much faster and seems to be from the muffler. What on the muffler can make such loud and really fast clunking noises. its more like a really loud rattle and only happens occasionally.
    Charles, definitely check the brake pad sensors...i think thats the problem i had before i had the brakes changed last week.
    Washington D.C
    El Paso TX
    the mounts forward of the muffler are loose? bolt has backed out on one of them?
    Oldham, England
    Thanks guys!
    You have checked you dont have a stone or nail in a tyre?
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by Sixdown
    happened to me before, clanking noise at the rear while in idle. it was the rubber that supports the muffler.it was missing.
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
  1. Loud Ticking noise ... Relative to engine speed?
    Last Post: 03-05-2009, 04:34 PM
  2. Ticking lifters? Goes away when in gear
    By LunatiC in forum 5 Series BMW
    Last Post: 10-18-2008, 01:24 PM
  3. Ticking noise
    By Jer in forum 5 Series BMW
    Last Post: 04-20-2006, 11:05 AM
  4. Replies: 10
    Last Post: 11-27-2005, 09:11 PM
