Results 1 to 10 of 10
Thread: Ever repair a broken Heater valve wire?
    May 2006
    NH
    Default Ever repair a broken Heater valve wire?
    In spite of my best efforts I ended up breaking one of those minute wires to the valve in the Heater valve assembly when taking it apart to see if it was clogged and if i could clean it. It seemed perfectly clean everwhere but i broke one of the small wires coming from the power pins. They are extremely fine and very short . Has anyone ever repaired such a break? I have a soldering iron and solder but there's really no room to work with . Are they junk now?
    1995 540i Manual build 1/95
    Wellington,New Zealand
    well it must be worth a shot....were they blocked???
    Gone but not forgotten
    Great Britain
    Have you got a photo? It sounds as if you're talking about solenoid wiring - if so then just solder it to the terminal - you might need some extra wire to bridge the gap.
    May 2006
    NH
    Quote Originally Posted by Paul in NZ
    If i try it i'll take pictures.. The thing i dread is breathing the lead fumes... I'm already damaged enough,lol.
    May 2006
    NH
    Quote Originally Posted by pingu
    Yes the Solenoid wiring. Its under a little plastic cover at the base of the solenoids. I may give it a shot when I know I have enough time to give to it. It just looked like the wire was so fine I couldn't imagine a drop of solder adhering to it and also thought the wire itself might begin to melt. I might try taking a strand from some speaker cable i have and just replace the wire entirely
    Dec 2006
    Long Island
    lead free solder is widely available.
    I usually just time my breaths anyway, soldering such a small wire shouldn't produce too much byproduct.
    Great Britain
    I think it's about time for a photo! In the meantime, I suspect you'll be able to scrape of the insulation off the last few millimetres of the wire so that you've got a reasonable length to solder onto. On some types of wire, a (hot!) soldering iron will burn through the insulation. But don't breath in the fumes from the wire.
    May 2006
    NH
    The Unit is installed in the car. I don't have a spare. When i take it out again I'll snap pix. All the solenoid wires are bare. I think if i try soldering i'd have better luck removing the two halfs and soldering in an entire new wire.
    May 2006
    NH
    Here's the pic of the wires if you've never seen them. I have to believe it was broken before beacuse..... I went ahead to the Dealership and bought a new part,installed it and PROBLEM 100% SOLVED!
    usually they break here where they go into the valve,
    plus more pics
  1. Heater control valve repair (Shogun?)
    By Craig in Davis in forum 5 Series BMW
    Last Post: 09-19-2013, 10:37 AM
  2. trunk wire loom repair
    Last Post: 05-07-2010, 09:01 AM
  3. Replies: 2
    Last Post: 03-25-2009, 07:47 PM
  4. wire rotation on heater valve
    Last Post: 11-04-2008, 09:30 PM
  5. possible to repair heater valve/pump?
    By 8 POTS in forum 5 Series BMW
    Last Post: 09-13-2005, 04:50 AM
