I had a fuse blow for my passenger low beam. After I replaced the fuse the headlamp still didn't work, so I tried a different bulb but still no go. The car only tells me that there's a problem with the low beam when I physically disconnect the bulb. Does anyone know if there is a relay for the headlamps that could have blown or something?
LKM... you need to resolder the relay for your low beam inside the LKM... refer to bruno's website for info. The tip is to resolder the two solder contacts on the moving switch side... add more solder too.
