Results 1 to 7 of 7
Thread: What tire pressure do you run.....
    Nov 2006
    Germany
    Quote Originally Posted by robert g
    What tire pressure do you all run on your car. Do you run more in the rear and less in the front? I have 18" wheels and I am running 32 psi but the tire seems under pressure. The tire from the side looks concave. On my other car the tire calls for 36 and the tire all so looks concave. The center of the tire looks low. Thanks again.
    Due to my car being lowered, I run more tire pressure than BMW recommends. Something like, 38psi up front and 41psi out back. Otherwise, I get too much wear on the inside edges due to the negative chamber (from the lowered stance without chamber plates).
    Brian
    Mar 2007
    Liverpool UK
    I run 37psi front and back with 235-45-r18's... Seems to work pretty well.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    arkansas
    Default What tire pressure do you run.....
    Jan 2007
    San Jose, CA
    If the center is worn, but the outsides have more tread, your pressure is too high. If the outsides are worn, but the center has more tread, your pressure is too low.
    You'll have to experiment if you're using a tire size which is not stock. Alot of this pertains to the way the car will handle. For instance, my old '63 Bel Air wagon had tire pressure setups for when the rear was loaded down, heavily and when it was not loaded down, which had to be adjusted correctly or the steering would get scary; all this being during a time that bias-ply tires were what you would use rather than radials.
    On my 525i's stockers, I usually ran them at about 5 pounds below maximum cold pressure. They are 44psi max cold so I usually ran 40psi, but recently when I tried lowering the rears to about 30-32psi I noticed that handling on this windy downhill I take to work improved! Probably due to a larger contact patch.
    Wellington,New Zealand
    38 front 40 rear...I run lower pressures sometimes for a slightly better ride,but the handling and tyre wear suffer.I always pump up for road tripa and or higher sped or car club runs...
    Gone but not forgotten
    Houston, TX
    36 psi front, 41 rear. Stock wheels and tires. Lots of 75+ mph freeway driving.
    May 2006
    NH
    I run the psi listed on the Door jam.
    1995 540i Manual build 1/95
  1. Tire pressure
    By mitch2k in forum 5 Series BMW
    Last Post: 07-03-2006, 03:06 PM
  2. ::.. Tire Pressure
    By Qube in forum 5 Series BMW
    Last Post: 05-06-2006, 12:01 AM
  3. Tire Pressure?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 08-10-2005, 07:44 PM
  4. Tire Pressure help
    By kentish in forum 5 Series BMW
    Last Post: 04-17-2004, 09:19 PM
  5. Tire Pressure 101
    By Level8Drummer in forum 5 Series BMW
    Last Post: 03-31-2004, 11:22 PM
