Results 1 to 5 of 5
Thread: 540i thrust arm replacement
    Mar 2008
    Default 540i thrust arm replacement
    I'm trying to replace the thrust arms on my dad e34 540i and everything went smooth until I tried to tighten up the bolt on the ball joint end. The ball joint kept spinning. Is there a trick to keep them from spinning to I can tighten it up. To me, it's such a stupid design from Lemforder thrust arms. On my e30, there's a slot on top of the balljoint for you to use the wrench and stop it from spinning. Please help.
    use a c clamp there.
    New thrust arm spinning at the ball joint? Sometime there is a slot where you can put a wrench on that ball joint shaft to keep it from spinning. Still, most new thrust arm ball joint should never move when you tighten it up.
    Mar 2007
    Liverpool UK
    Defective Balljoint... Get a new one.
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Mar 2008
    Quote Originally Posted by BigKriss
    Thanks for the tip. I used a 5" C clamp and it worked beautifully.
    QN
  1. Thrust Arm Replacement
    By Chazmati in forum 5 Series BMW
    Last Post: 01-28-2008, 12:09 PM
  2. Thrust arm replacement
    By Incantation in forum 5 Series BMW
    Last Post: 02-02-2005, 01:05 PM
  3. Thrust Arm replacement method
    By andyman32 in forum 5 Series BMW
    Last Post: 10-20-2004, 08:44 PM
  4. Thrust arm replacement question
    By ilya in forum 5 Series BMW
    Last Post: 04-10-2004, 09:16 PM
  5. Thrust Arm replacement question....
    By MO525 in forum 5 Series BMW
    Last Post: 02-29-2004, 04:53 PM
